Browse Forums Building A New House 1 Aug 26, 2016 1:59 pm Hi All, I am a newbie 1st time posting.Anyone building or built a double storey LIFESTYLE range house with PD,please share your views regarding upgrades,hidden costs,delays,suggestions etc. BTW we are interested in building a Marbella 38.. Re: Porter Davis double storey 2Aug 26, 2016 4:06 pm Newhouse22 Hi All, I am a newbie 1st time posting.Anyone building or built a double storey LIFESTYLE range house with PD,please share your views regarding upgrades,hidden costs,delays,suggestions etc. BTW we are interested in building a Marbella 38.. Hi Newhouse22 - We are building a Madison 45 as part of a KDR. Had our WOS appointments last week which were a lot of fun, albeit quite tiring. What stage are you up to? Currently working through the upgrades post WOS. Over budget but not too bad. Looking forward to the build ahead. December site start. Re: Porter Davis double storey 3Aug 26, 2016 9:08 pm Hi Madison-45, Madison is such a beautiful house,its also one of our options but Madison 40. We are in a confused state as haven't decided between Carlisle Granada Retreat /Marbella38/Madison40 What upgrades you are doing with Madison? Re: Porter Davis double storey 4Oct 06, 2016 5:10 pm Newhouse22 Hi All, I am a newbie 1st time posting.Anyone building or built a double storey LIFESTYLE range house with PD,please share your views regarding upgrades,hidden costs,delays,suggestions etc. BTW we are interested in building a Marbella 38.. Have you build with Pd? Re: Porter Davis double storey 6Oct 06, 2016 6:24 pm Yes I have given deposit for a Madison 40 , Bapontar Re: Porter Davis double storey 7Oct 10, 2016 4:07 pm Long time follower, first time poster. We have just paid our deposit for the Madison 40, we choose a lot of additional upgrades and costs. looking forward to our WOS appointments as i'm sure there will be many most costs and upgrades. Re: Porter Davis double storey 10Oct 11, 2016 3:58 pm Newhouse22 What upgrades have you done dc_85? see below. Facade - Bronte $7,500 Structural *Provide Madison 40 Grand Alfresco Option Including: - Approximately 6470mm deep x 5030mm wide Alfresco with M class concrete slab in lieu of standard - Redesigning of roof lines with additional category 1 concrete roof tiles - 3No. 470mm x 470mm brick pier. 1.0 $7,904 *Provide 2590mm high ceilings to first floor in lieu of standard 2440mm high ceilings. Note: Subject to compliance with wall height *regulations. 1.0 $3,718 *Provide 450mm wide eaves to the upper floor of the home. Note: Height of windows on sides and rear of house to be adjusted to match bottom of eave sheets excluding sliding doors and Bathroom windows (ie: No brickwork over windows due to the eave height). Note: Not applicable to 2740mm high ceilings. 50.0 $2,650 Doors Provide 1 No. 2040mm high x 1020mm wide Flush panel door to the Retreat in lieu of the standard 2040mm high x 820mm wide flush panel door. 1.0 $33 Provide 1No. 2340mm high flush panel door to First Floor in lieu of standard 2040mm high flush panel door. 6.0 $462 Provide 1No. 2400mm high x 3600mm wide Aluminium Boutique stack sliding door (3No. panels) to Living rear external wall in lieu of standard 1500mm high x 2700mm wide Aluminium double sliding window. 1.0 $690 $759 Provide 1No. 2400mm high x 2700mm wide Aluminium Boutique sliding door to Dining/Alfresco wall in lieu of standard 2100mm high x 2900mm wide Aluminium bi-parting sliding door. 1.0 $674 Provide 1No. Corinthian Quickslide RMDF2 unit including 2No. 2040mm high x 720mm wide flush doors with finger grips in lieu of standard 2040mm high x 720mm wide Flush Panel robe doors. 3.0 $609 Plaster Provide MDF bulkhead above Galley overhead cabinets 1.0 $89 Provide 1No. 425mm high x 425mm wide x 90mm deep tiled niche to the Bathroom shower wall. Note: The niche is located 1200mm from floor level. All niche dimensions are timber dimensions. 1.0 $176 Provide 1No. 425mm high x 425mm wide x 90mm deep tiled niche to the Ensuite shower wall. Note: The niche is located 1200mm from floor level. All niche dimensions are timber dimensions. 1.0 $176 Heating & Cooling Provide refrigerated cooling to the whole House, excluding utility areas, as per standard layout. Price Includes: Brivis Mx30iXA gas ducted heating with Brivis DI-XU18Z/DO-SC18Z9 18KW (3 phase) add on air conditioning dual Network thermostats, two zone controls, R1.5 ductwork and R0.4 insulated fittings installed to 14 outlets. Note: Refrigerated Air conditioning systems are designed to maintain an indoor temperature of 24 degrees C to the active zone, when the outdoor ambient temperature is below or equal to 35 degrees C. If the system is running all zones at once, it will not be as effective, and may not meet the above temperatures. Only one zone is to be operated at one time. 1.0 $16,452 Tiling Miscellaneous Provide additional Category 1 wall tiling to the Bathroom in lieu of standard plaster finish. 10.393 $800 Provide additional Category 1 wall tiling to the Ensuite in lieu of standard plaster finish 9.8 $755 Provide additional Category 1 wall tiling to the Powder Room in lieu of standard plaster finish. 4.87 $375 Cabinets Provide Madison 40 Sunbury Galley cabinet option including; approximately 900mm high x 2200mm wide Laminate cabinets (5No. doors), 33mm thick x 600mm deep clear below Laminated benchtop and approximately 920mm high x 1800mm wide Laminate overhead cabinet (4No. doors). Note: Price includes Hettich 907113400 handles, soft closers, Laminate end panels and overhang to overhead cabinbets. Price does not include MDF bulkhead, sink and tapware. 1.0 $2,135 Provide Laundry Overhead Cabinet Option 2 including 1850mm wide laminate overhead cabinet (5No. doors) to the Laundry / Powder room wall and approximately additional 300mm high category 1 wall tiles below laminate overhead cabinet in lieu of standard Laundry layout. Note: Price includes standard Laminex handles and laminate back and end panels. 1.0 $789 Security Systems & Vaccums Provide Electron EVS 2808 system comprising vacuum unit in Garage with 4 internal vacuum points, 9 metre hose, sock for hose, muffler, wand and cleaning tool set. 1.0 $2,255 Appliances Provide 1No. additional Blanco BOSE65XP 600mm wide Oven. 1.0 $684 Stairs - we've since upgraded stairs as per display with glass approx $10,500 Provide Contemporary Stair Option 1, including the following: Stair, - Stain grade open tread/under blocks (non slip grooves) with single paint grade (black) centre stringer, Balustrade, - Stainless steel 40mm square satin finish newel post, - Stainless steel 12mm round satin finish balusters, - Stain grade 68mm x 42mm handrail, - Stain grade 110mm x 32mm pencil round void plate and open under stair. Note: Includes balustrade to first floor void area and open under stair. All dimensions are approximate. 1.0 $7,289 Carpet Miscellaneous Provide Category 1 Rivendell Carpet. 151.093 $5,591 Items with Pricing to be confirmed at Tender Provide 2740 Ceilings ilo 2590 in promotion 1.0 $3,718 Provide Square Set ceiling to ground floor ilo standard 1.0 $3,500 Provide Square Set ceiling to first floor ilo standard 1.0 $3,500 Provide an allowance for 2no additional pot draws to kitchen. The cost is subject to items selected by customer and will be determined at contract appointment. 1.0 $550 Provide an allowance for 60mm edge to kitchen with 60mm apron ends. The cost is subject to items selected by customer and will be determined at contract appointment. 1.0 $2,300 Provide 1No. 2100mm high x 2100mm wide Aluminium Boutique square set reveal fixed picture window to Dining rear external wall in lieu of standard 1500mm high x 2700mm wide Aluminium sliding window. Please Note: Window head height to be set at 2400mm high. 1.0 $1,956 Provide 1No. 2100mm high x 1800mm wide Aluminium Boutique square set reveal fixed picture window to Dining side external wall in lieu of brickwork. Please Note: Window head height to be set at 2400mm high. 1.0 $1,100 were yet to do our WOS app so expecting to spend additional on -kitchen bench top and cabinet upgrades -tap and sink upgrades -brick upgrade -down lights (electrical) and were doing our own timber flooring after hand over in (foyer,entry,kitchen,dining,family) Re: Porter Davis double storey 11Oct 12, 2016 10:25 am DC_85, I should have asked you what upgrades you haven't done.I have just paid the deposit and thinking to do the following:- After looking yours I forgot to add tiling to all bathrooms and adding extra window behind dining area I am doing the following plus will add more later after WOS appointment:- Structural *Provide 450mm wide eaves to the upper floor of the home. Note: Height of windows on sides and rear of house to be adjusted to match bottom of eave sheets excluding sliding doors and Bathroom windows (ie: No brickwork over windows due to the eave height). Note: Not applicable to 2740mm high ceilings. 60.0 $64 $4,200 *Provide 2740mm high ceilings to ground floor in lieu of standard 2440mm high ceilings. Note: Subject to compliance with wall height *regulations. 0.5 $6,760 $3,718 *Provide Madison 40 Guest Bedroom Option including the following: - Approximately 3540mm deep x 3240mm wide Guest Bedroom with WIR in lieu of Lounge room - Redesign Powder area to approximately 3150mm deep x 2190mm wide in lieu of standard - 1No 1000mm high x 600mm wide aluminium sliding window in lieu of 1No 2100mm high x 600mm wide aluminium awning window - 1No 1200mm x 900mm shower with semi frameless shower screen - 1No approximately 2040mm high x 820mm wide flush panel hinged and latched door to Bed 5 Guest Bedroom - 1No approximately 2040mm high x 820mm wide flush panel hinged and latched door access to Powder - 1500mm deep x 1251mm wide WIR with 450mm wide shelf and hanging rod. 1.0 $2,974 $3,271 SUB TOTAL $11,189 Heating & Cooling Qty Unit Inc GST Provide Brivis Promina evaporative cooling with manual wall control, R1 ductwork and R0.4 insulated fittings to 9 outlets including additional 1No. capped cold water point and 1No. single power point. 1.0 $6,155 $6,770 SUB TOTAL $6,770 SEIZE THE DREAM | Underfoot Luxury Inc GST Choice of flooring to the entry, kitchen, dining and family rooms: 1. Ceramic tiles OR 2. Bolero or Manhattan timber look flooring PLUS Rivendell carpet to the entire house excluding the tiled areas. $10,999 TOTAL $10,999 Cabinets Qty Unit Inc GST Provide Galley Cabinet Option 3 including laminate base cabinets (6No. doors) and benchtop to Galley on external wall, and laminate base cabinets (5No. doors) and benchtop to Galley on Galley / Linen wall, in lieu of standard bottom two melamine shelves. Note: Top two 300mm deep melamine shelves to remain, and price includes standard Laminex Handles and laminate back and end panels. 1.0 $1,671 $1,838 Provide Shadowline feature to all Kitchen benchtops. 1.0 $215 $237 SUB TOTAL $2,075 Plumbing Qty Unit Inc GST Provide 1No. additional capped hot water point for future appliance. 1.0 $114 $126 Provide 1No. additional capped Gas point. 1.0 $172 $189 Provide 1No. Mizu Drift 300mm Ceiling Dumper in White to Ensuite 1 overhead shower rose in lieu of standard. 1.0 $202 $222 Provide 1No. additional capped waste point. 1.0 $193 $212 Provide 1No. additional capped cold water point for future appliance. 1.0 $114 $126 SUB TOTAL $875 Windows Qty Unit Inc GST Provide approx. 350mm high x 2400mm wide fixed square set reveal window to Kitchen external side wall in lieu of standard tiles and brickwork. Located between the benchtop and overhead cabinets. Note: Window to be centred to benchtop. 1.0 $378 $416 SUB TOTAL $416 Doors Qty Unit Inc GST Provide 1No. Quickslide RMDF2 - 2 door unit with Fingertip in lieu of 2040mm high x 720mm wide hinged only doors. 1.0 $189 $208 *Provide 1No. 2340mm high x 920mm wide Madison 104 (PMAD 104) primed front entry door with clear glazing in lieu of standard 2040mm high x 820mm wide door. Note: Entry frame alterations be priced separately. (Required to suit non-standard door size) 1.0 $713 $784 SUB TOTAL $992 Plaster Qty Unit Inc GST Provide 1No. 425mm high x 425mm wide x 90mm deep tiled niche to the Bathroom shower wall. Note: The niche is located 1200mm from floor level. 1.0 $160 $176 SUB TOTAL $176 Provide 1No. 425mm high x 425mm wide x 90mm deep tiled niche to the Ensuite shower wall. Note: The niche is located 1200mm from floor level. All niche dimensions are timber dimensions. 2.0 $320 $352 SUB TOTAL $352 Custom Variations Items with Pricing to be confirmed at Tender Qty Unit Inc GST Provide 250mm extension to island bench with CAT 1 stone 1.0 $727 $800 Provide 1No. Mizu Drift SQ Mixer to Galley Sink 1.0 $182 $200 Provide 1No. Interchange AB420 Sink to Galley 1.0 $512 $563 Provide 1No. 425 x 425 x 90 Tiled Niche to Guest Ensuite Shower 1.0 $160 $176 Provide 1No. 2340 x 820 Internal Flush Panel access door from the garage in lieu of 2040 x 820 flush panel door 1.0 $227 $250 SUB TOTAL $1,989 Re: Porter Davis double storey 12Oct 12, 2016 2:55 pm Looks great, i look forward to hearing how you go at WOS, were yet to confirm our appointments. I was contemplating a long time on adding a window in the kitchen, but decided to go with a marble look splash back. Although the price below looks appealing. Windows Qty Unit Inc GST Provide approx. 350mm high x 2400mm wide fixed square set reveal window to Kitchen external side wall in lieu of standard tiles and brickwork. Located between the benchtop and overhead cabinets. Note: Window to be centred to benchtop. 1.0 $378 $416 SUB TOTAL $416 i'm sure we may have missed something in our quote, but hopefully will pick it up at all our other appointments. i feel much better seeing someone else having so many upgrades, the price adds up pretty quickly. Re: Porter Davis double storey 13Oct 13, 2016 8:29 am Yes Indeed the price adds up bloody quickly.I would love to see how your build goes dc-85. I have also asked for a quote to add little storage area (like a WIR) in activity upstairs next to the bath with a sliding door as there in not enough storage. I am planning to go to WOS this weekend to have a look Re: Porter Davis double storey 14Oct 17, 2016 10:32 pm Looking to build with pd and thinking of upgrading lots of items during color selectiom. Does anyone know if pd credit back upgrades to taps, bathroom sink, tiles, and other small ticket items? Re: Porter Davis double storey 15Oct 18, 2016 10:34 am Luinel Looking to build with pd and thinking of upgrading lots of items during color selectiom. Does anyone know if pd credit back upgrades to taps, bathroom sink, tiles, and other small ticket items? i'm not sure you will get a credit, i believe you just pay the difference in price from the std inclusions to the upgrade. Re: Porter Davis double storey 16Oct 18, 2016 11:49 am [quote="Luinel"]Looking to build with pd and thinking of upgrading lots of items during color selectiom. Does anyone know if pd credit back upgrades to taps, bathroom sink, tiles, and other small ticket items? Small items not sure but for big stuff e.g flooring you get credit. Go to nearest PD display and ask the sales team and they will be able to help ya. Re: Porter Davis double storey 17Oct 21, 2016 10:43 am Hi dc_85 Is this upgrade includes all tiling (wall to wall)in bathrooms? Tiling Miscellaneous Provide additional Category 1 wall tiling to the Bathroom in lieu of standard plaster finish. 10.393 $800 Provide additional Category 1 wall tiling to the En-suite in lieu of standard plaster finish 9.8 $755 Provide additional Category 1 wall tiling to the Powder Room in lieu of standard plaster finish. 4.87 $375 Re: Porter Davis double storey 19Oct 21, 2016 1:12 pm dc_1985 Yes, includes all tiling wall to wall. Thanks dc Re: Porter Davis double storey 20Nov 11, 2016 7:15 pm Going next week for WOS appointments any suggestions ? Three options 1 Ask the liquidator 2 Find another PD customer and ask the source of their report 3 Pay for new report 3 12345 1 4592 Hi Kristy Around $1.7-1.8m or around $4,600/sqm. if you PM me your email I will send you a break up in a spreadsheet so you can get an understanding of the costs for… 1 9980 |
