Browse Forums Building A New House 1 Aug 05, 2016 1:43 pm Hi Everyone, For those who have built homes with a colorbond roof... [1] Did you opt for extra insulation under the roof? [2] Was it worth it? [3] If you didn't install extra insulation... are things ok or would you go back and install some? Thanking you in advance ~ Re: Did you opt for insulation under a colorbond roof? 2Aug 05, 2016 2:29 pm Are you talking about Anticon or ceiling insulation? If you mean Anticon, I wish I'd gotten it. I didn't know about it before it was too late. We just moved in last week and it has been raining non-stop. The noise is tremendous. Re: Did you opt for insulation under a colorbond roof? 5Aug 05, 2016 4:53 pm I put 75mm foil backed insulation under my colorbond roof. In addition to its insulation and sound deadening properties, it also allows minor leaks or condensation under the roof to run into the gutter.
Sarking is also required in high fire risk areas as it prevents embers getting into the roof space. Re: Did you opt for insulation under a colorbond roof? 6Aug 05, 2016 5:38 pm 75mm anticon here, would recommend Custom build Northern NSW viewtopic.php?f=31&t=72217 Re: Did you opt for insulation under a colorbond roof? 8Aug 05, 2016 9:23 pm Yes, 75mm anticon. Also out additional rock wool blown in insulation into our double cavity walls that didn't need it to get the 6 star rating. Makes a huge difference and glad we did it. Re: Did you opt for insulation under a colorbond roof? 9Aug 06, 2016 4:26 pm No but i wish we had know before becuase i would have spent the extra $$. Oh well thats my fault You should pressure clean your roof first and make sure the paint you buy also is anti mould. 4 18578 Your house roof does not show rusting other than some surface rust on the flashings. In my opinion you dont need to replace or paint the roof other than treat surface rust… 1 10227 Hi all, Our boundary perimeter fences need replacing (3 sides). From everyone's experience, what would you install? Timber lapped and capped OR colorbond? Thank you. 0 2890 |
