Yes they should be able to.
Here in QLD, I got the last batch of the old doors, so they had to retrofit the screens for me. They told me anyone ordering the same doors after me will have built in screen tracks =(
Browse Forums Building A New House Re: KDR Metricon Liberty - Hampshire 45 QLD 1721Dec 19, 2017 11:15 am Renman So they can be retro fitted into the existing aluminum slider doors? Yes they should be able to. Here in QLD, I got the last batch of the old doors, so they had to retrofit the screens for me. They told me anyone ordering the same doors after me will have built in screen tracks =( Re: KDR Metricon Liberty - Hampshire 45 QLD 1722Dec 19, 2017 12:15 pm I just called the company and it can be retro fitted. Will be under ~$1k for the 4m slider door. My KDR Metricon Hampshire - Liberty - 45 Melb https://r.tapatalk.com/shareLink?share_ ... are_type=t Re: KDR Metricon Liberty - Hampshire 45 QLD 1723Dec 19, 2017 2:32 pm Renman I just called the company and it can be retro fitted. Will be under ~$1k for the 4m slider door. Yup just looked up my cost it was $980, so pretty much spot on. Re: KDR Metricon Liberty - Hampshire 45 QLD 1724Dec 19, 2017 3:21 pm Thanks for everyone providing the insulation cost. we have upgraded our wall insulation for $323.(R2.0) 1st quote we received 4893 2nd quote we received 1616 I can not believe how they calculate prices. Not sure how many things we been overcharged like this KDR Metricon Liberty - Hampshire 45 QLD 1727Dec 19, 2017 3:48 pm dulie Renman I just called the company and it can be retro fitted. Will be under ~$1k for the 4m slider door. Yup just looked up my cost it was $980, so pretty much spot on. Our ones were $1700 for 2 stacker doors but they are smaller at around 3.5m and 3.2m so the price sounds about right. Metricon Liberty 45, Ryde NSW http://forum.homeone.com.au/viewtopic.php?t=82846 Build thread: Metricon Liberty 45 in Ryde, NSW Re: KDR Metricon Liberty - Hampshire 45 QLD 1728Dec 19, 2017 5:34 pm Kandi The kitchen window glass, are they toughed? or we need to upgrade? since its closer to the gas stove. please share you experience? Just standard. It would have to meet what ever requirements for it to be there, or M wouldn't be able to use it. Re: KDR Metricon Liberty - Hampshire 45 QLD 1729Dec 19, 2017 6:09 pm These stacker doors look awesome! Can you kindly tell me which frames they are? Are they Horizon or Paragon for example? Thanks so much! My Metricon Glendale in Sydney. Re: KDR Metricon Liberty - Hampshire 45 QLD 1730Dec 19, 2017 6:09 pm Renman Kandi Just having a quick look 1. The Guest ensuite, behind the toilet there’s a void. Suggest you turn that into some shelves for towels and make use of the void space. 2. Dinning stacker doors, as it open directly outside and there’s no cover for the doors be careful that the doors are not to exposed to the elements and will damage it. Might get rain coming inside the house if there’s strong windy rain. 3. Do you have a lot of space between the garage and the side fence? Think about have large opening for easy access to the backyard for landscaping in the future. You one have one 820mm door. It won’t fit a bobcat through there. My KDR Metricon Hampshire - Liberty - 45 Melb https://r.tapatalk.com/shareLink?share_ ... type=tanan Thanks Renman have 450mm eves for the dinning. Yes you are right it is actually exposed. we need to do something after build. we have 1 meter between garage and the fence. we Re: KDR Metricon Liberty - Hampshire 45 QLD 1731Dec 19, 2017 9:19 pm HGMbuild These stacker doors look awesome! Can you kindly tell me which frames they are? Are they Horizon or Paragon for example? Thanks so much! Thanks, up in QLD M uses A&L windows. They are the upgraded "Boutique" sliding doors. http://www.alwindows.com.au/product/bou ... ding-doors I'm pretty sure each state has an equivalent upgrade option. NSW - Wideline Paragon VIC - Southern Star 300 Series Discussion from a while back on page 22 if you're on a pc. viewtopic.php?f=31&t=84171&start=420 Hope that helps. Re: KDR Metricon Liberty - Hampshire 45 QLD 1732Dec 19, 2017 9:39 pm dulie HGMbuild These stacker doors look awesome! Can you kindly tell me which frames they are? Are they Horizon or Paragon for example? Thanks so much! Thanks, up in QLD M uses A&L windows. They are the upgraded "Boutique" sliding doors. http://www.alwindows.com.au/product/bou ... ding-doors I'm pretty sure each state has an equivalent upgrade option. NSW - Wideline Paragon VIC - Southern Star 300 Series Discussion from a while back on page 22 if you're on a pc. viewtopic.php?f=31&t=84171&start=420 Hope that helps. Oh thanks so much, you’ve explained it perfectly! My Metricon Glendale in Sydney. Re: KDR Metricon Liberty - Hampshire 45 QLD 1733Dec 19, 2017 9:50 pm dulie Renman I just called the company and it can be retro fitted. Will be under ~$1k for the 4m slider door. Yup just looked up my cost it was $980, so pretty much spot on. Thought it might be cheaper going direct. My KDR Metricon Hampshire - Liberty - 45 Melb https://r.tapatalk.com/shareLink?share_ ... are_type=t Re: KDR Metricon Liberty - Hampshire 45 QLD 1734Dec 19, 2017 9:53 pm Kandi Renman Kandi Just having a quick look 1. The Guest ensuite, behind the toilet there’s a void. Suggest you turn that into some shelves for towels and make use of the void space. 2. Dinning stacker doors, as it open directly outside and there’s no cover for the doors be careful that the doors are not to exposed to the elements and will damage it. Might get rain coming inside the house if there’s strong windy rain. 3. Do you have a lot of space between the garage and the side fence? Think about have large opening for easy access to the backyard for landscaping in the future. You one have one 820mm door. It won’t fit a bobcat through there. My KDR Metricon Hampshire - Liberty - 45 Melb https://r.tapatalk.com/shareLink?share_ ... type=tanan Thanks Renman have 450mm eves for the dinning. Yes you are right it is actually exposed. we need to do something after build. we have 1 meter between garage and the fence. we One Meter won’t be enough for excavation machinery. Suggest you widen the garage back door with a roller door or two 820mm doors. My KDR Metricon Hampshire - Liberty - 45 Melb https://r.tapatalk.com/shareLink?share_ ... are_type=t Re: KDR Metricon Liberty - Hampshire 45 QLD 1735Dec 19, 2017 11:43 pm Agreed, having a big door or a roller door in our instant, has come in super handy in accessing the rear yard. Re: KDR Metricon Liberty - Hampshire 45 QLD 1736Dec 21, 2017 9:58 pm dulie Renman Dulie, Your house looks fantastic. Love your tapeware. I saw them at Reece they were over out budget. How much will the tiles cost you and to lay them? Thanks Renman, I must admit the basin mixers is definitely one of my favorite things about the house. =D Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ As for the tiles, one of the tenants of my rental property is a tiler. His doing at mates rates for me, it's too cheap to even mention. But generally I think most quotes I got back were anywhere between $70-100 per m2. Hey mate, can you remember how much these were? Also did you just ask M to get them for you or did you supply them? Re: KDR Metricon Liberty - Hampshire 45 QLD 1737Dec 22, 2017 11:02 am craigo dulie Thanks Renman, I must admit the basin mixers is definitely one of my favorite things about the house. =D Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ As for the tiles, one of the tenants of my rental property is a tiler. His doing at mates rates for me, it's too cheap to even mention. But generally I think most quotes I got back were anywhere between $70-100 per m2. Hey mate, can you remember how much these were? Also did you just ask M to get them for you or did you supply them? $422 each in lieu of standard. We got them with M, quite pricey especially when we needed to get 6 of them =S But then again, the RRP on their website is $675 each. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: KDR Metricon Liberty - Hampshire 45 QLD 1739Apr 08, 2018 9:37 am Dulie, this is an awesome thread. Thanks so much for all the information and congratulations on a great build! Re: KDR Metricon Liberty - Hampshire 45 QLD 1740Apr 19, 2018 5:41 pm Hi Dulie Yours is a beautiful house. We are building Liberty 40 (with All inclusions) except driveway and landscaping came in like $555654.00. Are we paying more than we should?? I am kinda worried because your house seem much bigger and you seemed to have spent much less than us. Can you please help us?Thanks Ilan. We were lucky in that our old house was so small (86 square metres) compared to the new house, they were able to take enough readings around the old backyard house before… 8 24824 The biggest challenge will be if you take out a loan and then run out of money - you'll have an incomplete security and lenders do not like this so you can get stuck.… 2 13508 Hi, I am looking into doing a KDR in Melbourne and am contemplating using Kialla Homes. I am looking for feedback on them from others who have built with them. 0 8188 |
