Browse Forums Building A New House 1 Jul 13, 2016 10:42 am hi all just needing some advice with an issue with our bricks. We had a meeting with our ss yesterday and noticed that the bricks above the kitchen window have a " swollen " look to them and the lintel is bowing. they were only built 2 weeks ago. it is a large double storey wall that it is supporting. the window in the theatre has a steel beam that they realised they needed after they started building and is carrying less weight so shouldn't the kitchen window have the same?? what would be the recommended fixes? any advice is welcome please Re: advice needed 2Jul 13, 2016 3:09 pm Groovycookie any advice is welcome please You need to... 1. Use a descriptive thread title to get attention and to also help others who later do a forum search for information about their own similar problem. 2. You need to post in the correct sub forum. In this instance, the correct sub forum is Building Standards; Getting It Right! You are much more likely to get the correct advice from a building professional by doing so. 3. Post photos to help others to help you. Hope this helps. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Hi All, I engaged a tradie to install concrete retaining wall 600-800mm high over 32 meters in Victoria. Sleepers are 200*75*2000 mm installed over 17 steel posts. I… 0 7039 Building Standards; Getting It Right! Don't think they are designed for double brick. WA has a particular way of building and unfortunately that's the way a large amount of sills are finished. 3 7101 Versaloc is a mortarless besser block system that still needs a properly engineered footing. If you just do a 400x200 footing it will fail in time. At 17m long you need it… 1 18888 |
