Browse Forums Building A New House 1 Jul 01, 2016 11:21 pm Hi guys, Need your recommendation and assistance to decide between two different air-con zoned configuration. If you are building two story house with 4 bedrooms + study + theater + 3 living rooms in Sydney West area, and you have the option to select the set up of your air-con. Which of the following will help to save dollars in terms of running cost and maintenance for 5 years time? 1. 2 Zoned Air-con + Solar Power System, initial cost is $11K 2. 4 Zoned Air-con, initial cost is $5K We really appreciate your time. Navy navylion Building a Wisdom Homes Manhattan 35 in Sydney North West MyBuildTimeLine: http://navylion.wixsite.com/mybuildtimeline Re: 2 Zoned Air-con + Solar vs 4 Zoned Air-con 2Jul 02, 2016 7:48 pm The answer will depend on how you intend to use the spaces as a family and how you tiller are heat etc. I would opt for the 2 zone so more of the house can be cooled at once. The 4 zone would probably be only cooling a small section at once. So if your family is spread out through the house that may not work for you or the opposite. However for running a costs I would say that the 4 zone would be much cheaper because it would be cooling half the area How do you remove one of these ceiling air con vents? And is it possible to disconnect the duct joined to the vent from inside the house, without going into the roof cavity? 0 5936 Hi all, sorting out the ducted air con for a 350sqm double story house. Does this placement sound reasonable to you? Also, I plan to have 6 zones I think. Living room… 0 0 Hi all, sorting out the ducted air con for a 350sqm double story house. I think i plan to have 6 zones I think. Living room (mainly for entertainment so not used often),… 0 0 |
