Browse Forums Building A New House 1 Jun 27, 2016 2:44 pm I've only been in my new single storey house for a few months and for most of that time I've noticed that the drain in the middle of the ensuite floor often has air blowing up through it. When I first moved in I noticed some water in the drain but haven't seen any water for ages. It is quite breezy standing over the drain and can be quite noisy. Is this normal? The house has a waffle pod slab. The floor drain in the main bathroom is on the same side of the house but doesn't have any breeze blowing up through it. This drain just seems to bring back up all the bubbles from bubble baths or too much hand wash used in the sink. No bubbles come up though the ensuite floor drain. I have no idea if this is normal because it has never happened in any other house I've lived in. Re: Air blowing up through bathroom drain 2Jun 27, 2016 8:47 pm Strange ? Pour some water down the drain and see if that stops it...maybe the water in the trap has evaporated My build with FHBD viewtopic.php?f=31&t=78344 Yeah mine about 9 metres long and 8 wide with slope of 25% at one point but the end point of the outlet is past the side of garage and if he concretes allowing for… 4 4534 Agreed. I just found out today the certifier has not given the final sign off. 2 4090 Grab a hose, insert it at the top of the inlet/down pipe and turn the water on and see where the water is escaping from. Then you'll know. 3 8465 |
