Browse Forums Building A New House 1 Jun 18, 2016 10:05 am currently awaiting a tender from beechwood for a split on the baudeaux guest. Anyone had any experience with doing splits with beechwood? what sort of costs were added for the split.. They had to do contours prior to tender just seems to be dragging on and on. Re: Beechwod Split Level Costs 2.5mt 2Jun 18, 2016 2:59 pm Hi Tom2016, we built the Lexia Slim Twist by Beechwood in 2015 and have a split. We have a 2.5mtr fall across our block rear to front. The cost for our split was $10,282 which includes 8 course step down (4 stairs). This is in addition to the Fixed Priced Site Costs $19,716, Provisional Allowances $8,400, Basix $11,766 and Council Requirements $4115... Also with a fall that deep think about retaining walls, we had to have a 1m wall at the back and on one of the sides and it cost us around $16k! It will cost us another $16k to finish off the landscaping. We definitely learnt our lesson with getting a sloped block! I hope this helps, check out my blog there should be pics of the split on it... Lexia Slim Twist with Beechwood Homes http://houseoflexia.blogspot.com.au/ https://www.instagram.com/natlyn7/ Move your linen into laundry and access laundry from your present linen space 1 8017 isn't a garage level with the rest of the house a given? pretty sure they 'came around' long time ago. if you have a flat block, the garage is usually level with the rest… 1 17528 they can, it's a fairly standard solution when the slab isn't recessed. the falls need to be in the main floor, if it hasn't been done then you need to ask them to redo… 4 6595 |
