Hi Jason
Do you mind sharing the company that did your driveway looks good.
Thanks I'll check with M and get back to you
Jason
Browse Forums Building A New House Re: My Metricon Phoenix in Melbourne 481Jan 05, 2017 8:29 pm Nataly Hi Jason Do you mind sharing the company that did your driveway looks good. Thanks I'll check with M and get back to you Jason My Phoenix by Metricon in Melbourne viewtopic.php?f=31&t=83584&p=1570829&hilit=my+phoenix+by+metricon+in+melbourne#p1570829 Re: My Metricon Phoenix in Melbourne 482Jan 05, 2017 8:32 pm Question re add on cooling to ducted heating...in hindsight should have done it during the build however need some professional advice! I've spoken to a lot of AC companies & the views were mixed. Some said I can easily add it on now, replace upstairs ducting & patch into existing for downstairs and performance will be fine. Others suggested performance will be heavily impacted using existing ducts. Has anyone been in a similar situation / have a professional position on this? I may play it safe and install split systems otherwise as I don't want to fork out a lot of money for a sub optimal system! My Phoenix by Metricon in Melbourne viewtopic.php?f=31&t=83584&p=1570829&hilit=my+phoenix+by+metricon+in+melbourne#p1570829 Re: My Metricon Phoenix in Melbourne 483Jan 05, 2017 9:00 pm jasonwg Question re add on cooling to ducted heating...in hindsight should have done it during the build however need some professional advice! I've spoken to a lot of AC companies & the views were mixed. Some said I can easily add it on now, replace upstairs ducting & patch into existing for downstairs and performance will be fine. Others suggested performance will be heavily impacted using existing ducts. Has anyone been in a similar situation / have a professional position on this? I may play it safe and install split systems otherwise as I don't want to fork out a lot of money for a sub optimal system! What ducts do you have at the moment? I spoke to an installer that stocks Actron, Fujitsu and Daikin today and they can install it post handover. They actually prefer to do the ducts and the unit fully instead of having it half done with the ducts from the builder. This way they can guarantee the work. Not sure how much more efforts it will be, I am waiting for the quote from them. Will let you know how it goes. Re: My Metricon Phoenix in Melbourne 484Jan 05, 2017 9:12 pm So do you mean you just got normal ducted heating through metricon and you are looking to add on refrigerated cooling to it now? I didn't know that was an option! What sort of price have you been quoted from those that said it was possible? Re: My Metricon Phoenix in Melbourne 485Jan 05, 2017 9:48 pm kylz4 So do you mean you just got normal ducted heating through metricon and you are looking to add on refrigerated cooling to it now? I didn't know that was an option! What sort of price have you been quoted from those that said it was possible? No. I got a quote from M to have to refrigerated cooling with a Actron unit. But I wanted to see if I can get a 3rd party contractor to quote and install the same or similar unit after handover to see if it would be cheap than M or not. Re: My Metricon Phoenix in Melbourne 486Jan 05, 2017 10:14 pm jasonwg Question re add on cooling to ducted heating...in hindsight should have done it during the build however need some professional advice! I've spoken to a lot of AC companies & the views were mixed. Some said I can easily add it on now, replace upstairs ducting & patch into existing for downstairs and performance will be fine. Others suggested performance will be heavily impacted using existing ducts. Has anyone been in a similar situation / have a professional position on this? I may play it safe and install split systems otherwise as I don't want to fork out a lot of money for a sub optimal system! How much would this cost Jason? We opted for splits downstairs only for that reason because we upgraded our ducted heating and it's zoned for 4 areas but if they could re add cooling to existing ducted heating at a reasonable price it may be worth considering Re: My Metricon Phoenix in Melbourne 487Jan 06, 2017 6:49 am Thanks for all the replies. Basically when I uograded my heating unit to ensure it could be zoned and more efficient, I chose a model compatible with add on refrigerated cooling. Naive a little at the time, I didn't realise this meant different duct work would also be required to what was specified as the upgrade cost was already pretty big. So in essence I have a compatible unit for the refrigerated add on to be installed, however the ducts aren't large enough and would at least need to be replaced upstairs - they can't do that downstairs because of access and size of current voids. This concerns me as different contractors have said that cooling requires much larger ductwork to be effective. Basically putting in the add on refridgeration cooling would solve upstairs however I worry about downstairs performance. The quotes I have involve adding the largest single phase unit available, 17kw, replacing all ductwork upstairs and tapping into existing downstairs plus increasing & relocating size of return air. They vary from $10-12k. Or I could go 2 split systems, thinking 8.5kw for down & 7 for up and this would be about $5k installed. But the upstairs cooling would then be very limited to where the split is (master / retreat). My Phoenix by Metricon in Melbourne viewtopic.php?f=31&t=83584&p=1570829&hilit=my+phoenix+by+metricon+in+melbourne#p1570829 My Metricon Phoenix in Melbourne 488Jan 06, 2017 8:57 am jasonwg Thanks for all the replies. Basically when I uograded my heating unit to ensure it could be zoned and more efficient, I chose a model compatible with add on refrigerated cooling. Naive a little at the time, I didn't realise this meant different duct work would also be required to what was specified as the upgrade cost was already pretty big. So in essence I have a compatible unit for the refrigerated add on to be installed, however the ducts aren't large enough and would at least need to be replaced upstairs - they can't do that downstairs because of access and size of current voids. This concerns me as different contractors have said that cooling requires much larger ductwork to be effective. Basically putting in the add on refridgeration cooling would solve upstairs however I worry about downstairs performance. The quotes I have involve adding the largest single phase unit available, 17kw, replacing all ductwork upstairs and tapping into existing downstairs plus increasing & relocating size of return air. They vary from $10-12k. Or I could go 2 split systems, thinking 8.5kw for down & 7 for up and this would be about $5k installed. But the upstairs cooling would then be very limited to where the split is (master / retreat). Good luck with what ever decision you take. I would stick with the 2 split given that you would spent most of your days downstairs on hot days. Then use the money that you would save to install Solar panels. $10-$12K for a retro solutions still sounds pretty good given that M is quoting me for a phase 3 Actron solution for $27K during the build stage. Re: My Metricon Phoenix in Melbourne 489Jan 06, 2017 10:15 am Upstairs is where it will be hottest, ground floor should stay fairly cool if the house is kept closed up and as long as it sits under the first floor part. I don't think it would have to be super strong in that area to be effective!? We have upgraded to zoned heating and 4 star unit but I don't know if it's compatible for add on later!? Re: My Metricon Phoenix in Melbourne 491Jan 06, 2017 1:04 pm vdn333 hi can you please tell me the colour of your garage external door? its really nice... Thanks, it's timbergrain caoba - tried to match it with the stains on the windows & door My Phoenix by Metricon in Melbourne viewtopic.php?f=31&t=83584&p=1570829&hilit=my+phoenix+by+metricon+in+melbourne#p1570829 My Metricon Phoenix in Melbourne 492Jan 06, 2017 1:05 pm kylz4 Upstairs is where it will be hottest, ground floor should stay fairly cool if the house is kept closed up and as long as it sits under the first floor part. I don't think it would have to be super strong in that area to be effective!? We have upgraded to zoned heating and 4 star unit but I don't know if it's compatible for add on later!? That's what I thought too - it still can get warm downstairs though given all the glass in the open plan area but nothing like upstairs which felt like an oven the other week & because it's so well insulated the heat takes time to escape!! Re compatible units, the fact yours is 4 star and zoned is a good starting point. It needs to be an extra air unit, ie a mod with a + at the end. Check with M what unit they've selected, presume a Brawmar around 30kw so similar to mine. So confused on what to do! My Phoenix by Metricon in Melbourne viewtopic.php?f=31&t=83584&p=1570829&hilit=my+phoenix+by+metricon+in+melbourne#p1570829 Re: My Metricon Phoenix in Melbourne 493Jan 06, 2017 1:41 pm Renman jasonwg Question re add on cooling to ducted heating...in hindsight should have done it during the build however need some professional advice! I've spoken to a lot of AC companies & the views were mixed. Some said I can easily add it on now, replace upstairs ducting & patch into existing for downstairs and performance will be fine. Others suggested performance will be heavily impacted using existing ducts. Has anyone been in a similar situation / have a professional position on this? I may play it safe and install split systems otherwise as I don't want to fork out a lot of money for a sub optimal system! What ducts do you have at the moment? I spoke to an installer that stocks Actron, Fujitsu and Daikin today and they can install it post handover. They actually prefer to do the ducts and the unit fully instead of having it half done with the ducts from the builder. This way they can guarantee the work. Not sure how much more efforts it will be, I am waiting for the quote from them. Will let you know how it goes. Thanks Renman, very keen to know what you've been quoted for something similar and how they will address downstairs ducting post build! My Phoenix by Metricon in Melbourne viewtopic.php?f=31&t=83584&p=1570829&hilit=my+phoenix+by+metricon+in+melbourne#p1570829 Re: My Metricon Phoenix in Melbourne 494Jan 06, 2017 2:40 pm Jason, How are you finding the lighting around the house? Do you find it bright enough with the number of down lights you have? Would you add more if you had a chance to do it again? Re: My Metricon Phoenix in Melbourne 495Jan 06, 2017 2:51 pm dulie Jason, How are you finding the lighting around the house? Do you find it bright enough with the number of down lights you have? Would you add more if you had a chance to do it again? That's a good question Dulie. I am keen to know since I've got only 4 x 11w led in each of the sitting living and dinning area. Was going to upgrade it to six in the living and dinning area. Re: My Metricon Phoenix in Melbourne 496Jan 06, 2017 2:53 pm dulie Jason, How are you finding the lighting around the house? Do you find it bright enough with the number of down lights you have? Would you add more if you had a chance to do it again? Can't say we've had any issues, the light is generally good in bedrooms and living areas - there's plenty of them. The one change I would make is adding downlights to the ensuite as we just have a main 4 in 1 light switch and whilst it is OK, over the shower isn't overly bright in early morning when I'm getting ready for work / late at night. My Phoenix by Metricon in Melbourne viewtopic.php?f=31&t=83584&p=1570829&hilit=my+phoenix+by+metricon+in+melbourne#p1570829 Re: My Metricon Phoenix in Melbourne 497Jan 06, 2017 2:53 pm Renman dulie Jason, How are you finding the lighting around the house? Do you find it bright enough with the number of down lights you have? Would you add more if you had a chance to do it again? That's a good question Dulie. I am keen to know since I've got only 4 x 11w led in each of the sitting living and dinning area. Was going to upgrade it to six in the living and dinning area. You can always increase the LED to 13W or 15W if not bright enough? @Orph Build thread: viewtopic.php?t=78328 Home Furniture: viewtopic.php?t=80551 Technology Hub: viewtopic.php?t=83663 Landscape Design: viewtopic.php?t=80645 Orpheus Building the Metricon Glendale 38|Sydney Re: My Metricon Phoenix in Melbourne 498Jan 06, 2017 3:00 pm Orpheus Renman dulie Jason, How are you finding the lighting around the house? Do you find it bright enough with the number of down lights you have? Would you add more if you had a chance to do it again? That's a good question Dulie. I am keen to know since I've got only 4 x 11w led in each of the sitting living and dinning area. Was going to upgrade it to six in the living and dinning area. You can always increase the LED to 13W or 15W if not bright enough? @Orph Build thread: viewtopic.php?t=78328 Home Furniture: viewtopic.php?t=80551 Technology Hub: viewtopic.php?t=83663 Landscape Design: viewtopic.php?t=80645 we can make it brighter but can't change the coverage.... Re: My Metricon Phoenix in Melbourne 499Jan 06, 2017 3:19 pm Orpheus Renman dulie Jason, How are you finding the lighting around the house? Do you find it bright enough with the number of down lights you have? Would you add more if you had a chance to do it again? That's a good question Dulie. I am keen to know since I've got only 4 x 11w led in each of the sitting living and dinning area. Was going to upgrade it to six in the living and dinning area. You can always increase the LED to 13W or 15W if not bright enough? That's strange as we were only given the option of 10W or 11W 120deg angle with Beacon Lighting. RS-LIG_BDO-0140 LEDlux Infinity mini 600 lumen. jasomwg, What model downlights did you get? @Orph Build thread: viewtopic.php?t=78328 Home Furniture: viewtopic.php?t=80551 Technology Hub: viewtopic.php?t=83663 Landscape Design: viewtopic.php?t=80645 Re: My Metricon Phoenix in Melbourne 500Jan 06, 2017 4:06 pm Mine are just viewlight 10watt warm white If I were to criticise its just that it does change the colour of the tile and makes it look more yellow rather than white but apparently the warm is more 'homely' and less 'clinical' or so I was told in my consultation. My Phoenix by Metricon in Melbourne viewtopic.php?f=31&t=83584&p=1570829&hilit=my+phoenix+by+metricon+in+melbourne#p1570829 Hi, First of all, thank you to this community for sharing your thoughts and opinions. We are in early days of our pre-contract stage for Metricon Doulton and we are… 0 10753 Hello All 🙂 We are planning to start our journey of construction our first home. We zeroed down on Metricon and henley homes based on design suitable for our lot and… 0 8205 We don’t live in VIC so want to know the exterior colours of Lumiere display so we can see it at the paint shop. Not building with Metricon so my request went… 0 17335 |
