Browse Forums Building A New House 1 May 28, 2016 12:09 am Hi guys, Building a new house and alfresco slab is not part of the standard package. Builder has quoted me $5k for alfresco (21sqm) slab + tiling. Does this sound reasonable or outrageous? I am 50/50 at the moment but have heard/read that doing it with the main slab is better. I have been told that doing it after HO (ie 2 separate slab) will mean that the alfresco slab will likely crack and break away from the main slab over time... leaving a gap.. is this true? Thanks Re: Alfresco slab with builder or after HO? 2May 28, 2016 5:51 am I prefer with main pour. Not sure on that cost - maybe ask around - get a quote. $5k seems high to me - but it depends on so many factors. If done properly after HO it should be OK. Re: Alfresco slab with builder or after HO? 3May 28, 2016 9:05 am Hi Volmix I suggest you get 3 quotes and then compare them with the builders price. BTW there will be no problem with the alfresco slab engineering if done properly Post handover it sounds like Salesman scare tactics. I would have thought a third of that would be a fair price if they had included it in the initial build price. Its no different to buying a car they get you on the upgrades..goodluck Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Alfresco slab with builder or after HO? 4May 28, 2016 9:56 am Thanks guys. I guess I know I'm paying a premium if I was to get it done with the main pour with the builder. I guess my question is, is it wiorth the extra dollars to get it done with the main pour? Re: Alfresco slab with builder or after HO? 5May 28, 2016 2:22 pm volmix Thanks guys. I guess I know I'm paying a premium if I was to get it done with the main pour with the builder. I guess my question is, is it wiorth the extra dollars to get it done with the main pour? 5K just for the alfresco is pretty expensive. I'm getting my driveway and alfresco done with my builder (Plantation Homes) for 5K in total. Re: Alfresco slab with builder or after HO? 6May 28, 2016 2:26 pm 5k for the slab and tiling isn't outrageous. Expensive if it's just the concrete, not too bad for both. I prefer the alfresco slab to be part of the main slab and not have to muck around post handover so I'd probably do it with the build if it was me. Re: Alfresco slab with builder or after HO? 9Jun 28, 2016 11:44 pm I had this same question and found this thread through searching. From what I can gather there is no real benefit in getting the alfresco slab poured with the main slab other than convenience. The builders will charge around $140/m2 while a concreter will charge half that post build. My thoughts are to get the builder to do all the structural concrete, mainly for warranty and accountability. After that get a concreter in for driveway, paths, alfresco etc. Might delay moving in by a week or so but saves several thousand $$$. Re: Alfresco slab with builder or after HO? 10Jun 29, 2016 9:05 am See what price they can do for just the slab only, no tiling. Tell them that $5000 is just way over the top and unaffordable, and play it up a bit... then see what price they'll do the slab for. Personally I'd get it done as one fully engineered slab, because to ensure you won't have issues of the two slabs drifting away, you will need to get the alfresco slab engineered. If your soil type is S or even M, you probably won't have any issues, but if your soil is H1 or worse, then you will really need to get the alfresco slab engineered. Finally, it is your call alone. Owner Building at Jimboomba Woods in Logan City Qld. Blog : http://bandlnewhomebuild.blogspot.com H1 thread : viewtopic.php?f=38&t=68283 . Re: Alfresco slab with builder or after HO? 11Jun 29, 2016 8:49 pm I went through the builder for mine. Not sure how much I paid but I think the slab part was basically substituted for the paver price and then I paid more for the tiling. Mine was poured at the same time as the garage grano rather than at the main pour. I would think you would be able to get the whole lot done after handover for around 3k. I extended my slab as a cashy for $45 sq m and the tilers are charging me around the same price. My build with FHBD viewtopic.php?f=31&t=78344 The concreter will take and reuse. In my case I bought structural LVLs and scraped them back and used them as joists. 1 5178 Hello! I've alfresco pitch of 3 degrees sitting just below the highlight window. Need advice on below: 1. Will the 3 degree pitch be ok to drain the rain water? The roof… 0 4207 |
