Browse Forums Building A New House 1 Apr 25, 2016 10:05 am Re: Is this pipe with joint acceptable? 2Apr 25, 2016 11:26 am Yes, it is acceptable, there is evidence of primer and adhesive. Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Is this pipe with joint acceptable? 6Apr 25, 2016 2:59 pm Steel but hard to tell without seeing your engineering plans. Nothing to worry about Is this pipe with joint acceptable? 8Apr 25, 2016 3:27 pm There should be a detail for pipes penetrations Refer to other pages Re: Is this pipe with joint acceptable? 11Apr 25, 2016 4:27 pm Just be mindful this is a very very minor issue. Nothing will happen if they don't do it To my understanding early saw cuts are to control shrinkage cracks, so doing them now would be pointless. Control joints may reduce ugly cracking during periods of soil… 3 9863 Hi all I need a guidance on how far I need to space expansion joints in the concrete driveway and its type (keyway/foam.) Contraction joints are at 3m max for a 125 slab. Thanks 0 10947 Hi, I am planning to select San Selmo reclaimed original for the fascade of my build. I have seen many photos on line of the brick varying from a rustic to a neat finish.… 0 4582 |
