Browse Forums Building A New House 1 Apr 24, 2016 6:00 pm Our garage wall is on 7cm from our boundary so we were thinking of just use the garage wall as a boundary when we install a new wooden fence. Question is there is a slope between us and the neighbour which we would then have to fill. Is it ok to have the ground up against the garage wall or will this cause problems? Neighbours land is probably 10-20cm higher than ours. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Knockdown and rebuild - Sahara Q2 with Henley viewtopic.php?f=31&t=75715 Knockdown and rebuild - Sahara Q2 with Henley https://forum.homeone.com.au/viewtopic.php?f=31&t=75715 Re: Advice on Boundary fence and garage wall 2Apr 24, 2016 6:19 pm Hi, although it may look better I wouldn't do it as they could claim the land which would devalue your property. When they install the new fence just get them to put a fence panel between fence and garage wall. Nev _________________ Blog | ( will start once received tender ) H1 thread | https://forum.homeone.com.au/viewtopic.php?f=31&t=77665 thanks Chippy, i hope they have applied sealer but i am doubt to be honest, so i am gonna do this job after handover. 8 16291 You should be able to encase the sewer but you will need it designed and approved and access to lot 580 to do the work 2 17168 Can anyone recommend a good/affordable retaining wall and fence builder that I can get a quote from located in Sydney? 8 45831 |
