Browse Forums Building A New House 1 Apr 21, 2016 9:23 am I am after some advice on cleaning of residue from the exposed aggregate installation off my dark render. I have tried detergent and a scrubbing brush too no avail. I have tried a high water pressure (domestic) cleaner also to no avail. What is next step to try? I don't want to damage my dark coloured render surface at the front of my house. Re: Exposed aggregate residue on render clean off advice. 2Apr 21, 2016 9:40 am Try a wire brush (gently) Re: Exposed aggregate residue on render clean off advice. 7Apr 23, 2016 4:32 am Oh no! Hope you get a response soon from someone who's successfully done this. What does your concreter say? If it's "dunno"' please kick his pants for me If you don't get any more suggestions, call Simonds and ask -- the SS would know what the 'acid wash' solution is that the brick washers use under pressure. Exposed aggregate residue on render clean off advice. 9Apr 25, 2016 12:23 am c'mon peeps ... If you have you had this problem and rectified, please tell Goody how Re: Exposed aggregate residue on render clean off advice. 10Apr 25, 2016 6:04 pm I tried 1:1 vinegar and water today to no avail. No improvement at all. Next will be the brick cleaning acid diluted as required. After that I may just paint the render as my wife did not like the render colour all that much as it was not close enough to woodland grey colour. Re: Exposed aggregate residue on render clean off advice. 11Apr 25, 2016 8:13 pm Would have thought the high pressure water blaster would have got it off. Did you get up close with it? Ours has a rotating head - very effective. Sounds like you might be painting ? Re: Exposed aggregate residue on render clean off advice. 12Apr 25, 2016 10:34 pm TomCat Would have thought the high pressure water blaster would have got it off. Did you get up close with it? Ours has a rotating head - very effective. Sounds like you might be painting ? I think you may be right Tomcat. Oh well, it is only about 10 square metres of area. Re: Exposed aggregate residue on render clean off advice. 13Apr 25, 2016 11:30 pm Better let the Missus pick the colour ? Re: Exposed aggregate residue on render clean off advice. 14Apr 25, 2016 11:58 pm The diluted hydrochloric acid method is for mortar removal. Don't expect it will work on concrete. if you decide to use it anyway, be very careful and use proper protective gear. I would be taking photos and talking to the builder - or directly to the concreter if you hired them independently. Probably efflorescence Salts coming out of sand, cement products and mortar Water brings them to surface and when evaporates it stays Extremely difficult to get rid of 1 11665 Last year I had a gas leak at my house. 3 days later, I have about 1 sqm of my exposed aggregate paving broken up. I am not sure how to go about getting it repaired… 0 10489 After some ideas on making our patio kid friendly . Currently we have exposed aggregate. The patio faces west and is always in sun even though it has a shade directly… 0 4183 |
