Browse Forums Building A New House Re: Flat roof with fence - entertainment area 3Apr 19, 2016 8:30 am The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Flat roof with fence - entertainment area 5Apr 19, 2016 12:36 pm The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Flat roof with fence - entertainment area 7Apr 19, 2016 2:53 pm The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Flat roof with fence - entertainment area 9Apr 19, 2016 6:54 pm The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Flat roof with fence - entertainment area 10Apr 20, 2016 6:33 am bashworth Vascariz bashworth Basically there is a minimal cavity with typically some sort of Truss Joist (see this link for examples: http://anewhouse.com.au/2014/04/types-of-floor-joists/) This gives space for installing cables, pipes and insulation, but once the ceiling is installed you won't be able to get up to change things. Forgive me if I'm being naive, but why couldn't you create an access hatch / manhole and create enough cavity to allow someone to move around up there on beams etc? Basically you are suggesting building a 2.5 storey house which will be extra cost, probably look ugly (top heavy) and might run into height restrictions with the planners. I understand the extra cost element. The look, I'll have to work out with an architect to see how we can minimise the top heavy aspect, to help it blend in with surrounding houses. Yeah whether we can fit all this into the 9.5m height restriction will be interesting! Thanks so much for replying. CDC Housing Code 3 When to apply Floor Area external face of wall vs Gross Floor Area internal face of wall. Reading thru CDC Housing Code 3, lets take a lot 915sqm.… 0 16562 I would suggest you simply go and talk to council about your proposal, most councils are getting onboard with ancillary dwellings. There is no benefit in keeping it… 1 4114 I think I know the answer but just checking to see if anyone has had experience with it. I want to build a small 20 square metre retreat in my backyard, it will have a… 0 13890 |
