Browse Forums Building A New House Re: Metricon Liberty 45 in Ryde NSW 521Feb 24, 2018 10:04 pm We drove past today to see some more work had been done on the house.. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ The front cladding had been installed but still needs to be painted. We’re a bit anxious to see if the colour on the rendered pylons (Dulux Mavora) goes ok with the cladding colour (Dulux Colorbond Dune) Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ The bricks below the rendered pylon on the garage side have also been filled up, and a new down pipe has been installed. Metricon Liberty 45, Ryde NSW http://forum.homeone.com.au/viewtopic.php?t=82846 Build thread: Metricon Liberty 45 in Ryde, NSW Metricon Liberty 45 in Ryde NSW 522Feb 24, 2018 10:27 pm Something to consider for those that are building brick and rebated the slab for their stacker doors.. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ We had paid for brick infills above our stacker doors but we will still ended up with a significant gap of around 70mm of non-brick infill between the top of the stacker door and the bricks. (M’s tolerance is 85mm which is around the height of a standard brick with some mortar above and below.) In hindsight, part of the reason for our significant gap might be that we rebated the slab by around 40mm deep for the stacker doors. So if you’re building with brick and rebating the slab for the stacker doors, you may want to consider how it might affect any brick infills above the stacker doors and whether you can look into adjusting the stacker doors height or rebate depth to minimise the gap. (Our stacker doors were 2370mm high.) Metricon Liberty 45, Ryde NSW http://forum.homeone.com.au/viewtopic.php?t=82846 Build thread: Metricon Liberty 45 in Ryde, NSW Re: Metricon Liberty 45 in Ryde NSW 523Feb 25, 2018 7:06 pm Quirmeball1280 Something to consider for those that are building brick and rebated the slab for their stacker doors.. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ We had paid for brick infills above our stacker doors but we will still ended up with a significant gap of around 70mm of non-brick infill between the top of the stacker door and the bricks. (M’s tolerance is 85mm which is around the height of a standard brick with some mortar above and below.) In hindsight, part of the reason for our significant gap might be that we rebated the slab by around 40mm deep for the stacker doors. So if you’re building with brick and rebating the slab for the stacker doors, you may want to consider how it might affect any brick infills above the stacker doors and whether you can look into adjusting the stacker doors height or rebate depth to minimise the gap. (Our stacker doors were 2370mm high.) Metricon Liberty 45, Ryde NSW http://forum.homeone.com.au/viewtopic.php?t=82846 So what is going to be in that gap now? Surely they can’t leave it empty? Re: Metricon Liberty 45 in Ryde NSW 524Feb 25, 2018 9:02 pm Brenton41 Quirmeball1280 Something to consider for those that are building brick and rebated the slab for their stacker doors.. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ We had paid for brick infills above our stacker doors but we will still ended up with a significant gap of around 70mm of non-brick infill between the top of the stacker door and the bricks. (M’s tolerance is 85mm which is around the height of a standard brick with some mortar above and below.) In hindsight, part of the reason for our significant gap might be that we rebated the slab by around 40mm deep for the stacker doors. So if you’re building with brick and rebating the slab for the stacker doors, you may want to consider how it might affect any brick infills above the stacker doors and whether you can look into adjusting the stacker doors height or rebate depth to minimise the gap. (Our stacker doors were 2370mm high.) Metricon Liberty 45, Ryde NSW http://forum.homeone.com.au/viewtopic.php?t=82846 So what is going to be in that gap now? Surely they can’t leave it empty? Yeah, I’m not sure what they will put to fill the gap - will try to find out from our SM before PCI Metricon Liberty 45, Ryde NSW http://forum.homeone.com.au/viewtopic.php?t=82846 Build thread: Metricon Liberty 45 in Ryde, NSW Re: Metricon Liberty 45 in Ryde NSW 526Feb 26, 2018 7:56 pm Quirmeball1280 Brenton41 Quirmeball1280 Something to consider for those that are building brick and rebated the slab for their stacker doors.. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ We had paid for brick infills above our stacker doors but we will still ended up with a significant gap of around 70mm of non-brick infill between the top of the stacker door and the bricks. (M’s tolerance is 85mm which is around the height of a standard brick with some mortar above and below.) In hindsight, part of the reason for our significant gap might be that we rebated the slab by around 40mm deep for the stacker doors. So if you’re building with brick and rebating the slab for the stacker doors, you may want to consider how it might affect any brick infills above the stacker doors and whether you can look into adjusting the stacker doors height or rebate depth to minimise the gap. (Our stacker doors were 2370mm high.) Metricon Liberty 45, Ryde NSW http://forum.homeone.com.au/viewtopic.php?t=82846 So what is going to be in that gap now? Surely they can’t leave it empty? Yeah, I’m not sure what they will put to fill the gap - will try to find out from our SM before PCI Metricon Liberty 45, Ryde NSW http://forum.homeone.com.au/viewtopic.php?t=82846 We had a similar problem above our bifold doors. They ended up filling with an aluminium plate same colour as frames... looks ok (after 2 attempts). Would still Have preferred bricks. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Metricon Liberty 45 in Ryde NSW 527Feb 26, 2018 10:08 pm VMGlendale37 Quirmeball1280 Brenton41 [quote="Quirmeball1280"]Something to consider for those that are building brick and rebated the slab for their stacker doors.. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ We had paid for brick infills above our stacker doors but we will still ended up with a significant gap of around 70mm of non-brick infill between the top of the stacker door and the bricks. (M’s tolerance is 85mm which is around the height of a standard brick with some mortar above and below.) In hindsight, part of the reason for our significant gap might be that we rebated the slab by around 40mm deep for the stacker doors. So if you’re building with brick and rebating the slab for the stacker doors, you may want to consider how it might affect any brick infills above the stacker doors and whether you can look into adjusting the stacker doors height or rebate depth to minimise the gap. (Our stacker doors were 2370mm high.) Metricon Liberty 45, Ryde NSW http://forum.homeone.com.au/viewtopic.php?t=82846 So what is going to be in that gap now? Surely they can’t leave it empty? Yeah, I’m not sure what they will put to fill the gap - will try to find out from our SM before PCI Metricon Liberty 45, Ryde NSW http://forum.homeone.com.au/viewtopic.php?t=82846 We had a similar problem above our bifold doors. They ended up filling with an aluminium plate same colour as frames... looks ok (after 2 attempts). Would still Have preferred bricks. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ [/quote] Thanks VMG, that’s probably what they will do to our one. It’s just frustrating that a few more millimetres and we could have fit an extra row of bricks How come your bifold doors have a few rows of bricks below them? Metricon Liberty 45, Ryde NSW http://forum.homeone.com.au/viewtopic.php?t=82846 Build thread: Metricon Liberty 45 in Ryde, NSW Re: Metricon Liberty 45 in Ryde NSW 528Feb 27, 2018 5:29 am Quirmeball1280 VMGlendale37 Quirmeball1280 [quote="Brenton41"][quote="Quirmeball1280"]Something to consider for those that are building brick and rebated the slab for their stacker doors.. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ We had paid for brick infills above our stacker doors but we will still ended up with a significant gap of around 70mm of non-brick infill between the top of the stacker door and the bricks. (M’s tolerance is 85mm which is around the height of a standard brick with some mortar above and below.) In hindsight, part of the reason for our significant gap might be that we rebated the slab by around 40mm deep for the stacker doors. So if you’re building with brick and rebating the slab for the stacker doors, you may want to consider how it might affect any brick infills above the stacker doors and whether you can look into adjusting the stacker doors height or rebate depth to minimise the gap. (Our stacker doors were 2370mm high.) Metricon Liberty 45, Ryde NSW http://forum.homeone.com.au/viewtopic.php?t=82846 So what is going to be in that gap now? Surely they can’t leave it empty? Yeah, I’m not sure what they will put to fill the gap - will try to find out from our SM before PCI Metricon Liberty 45, Ryde NSW http://forum.homeone.com.au/viewtopic.php?t=82846 We had a similar problem above our bifold doors. They ended up filling with an aluminium plate same colour as frames... looks ok (after 2 attempts). Would still Have preferred bricks. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ [/quote] Thanks VMG, that’s probably what they will do to our one. It’s just frustrating that a few more millimetres and we could have fit an extra row of bricks How come your bifold doors have a few rows of bricks below the them? Metricon Liberty 45, Ryde NSW http://forum.homeone.com.au/viewtopic.php?t=82846[/quote] Because according to M our sight had a slope and so when they did the cut and fill before they lay the slab they cut a fair bit from the back yard! To be honest we didn’t think it was required... As we wanted to avoid steps at the back we’ve filled it back up during landscaping. The deck now comes right up to line up with the top of the bricks. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Any the lawn meets the deck with a small step. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Metricon Liberty 45 in Ryde NSW 529Mar 01, 2018 6:53 am Hi all, as we are nearing practical completion, we noticed quite a bit of a gap (around 3cm) under our laundry door. Has anyone had any issues with gaps under doors? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ We’re a bit worried about this gap cause the door leads outside. Is there some standard or allowable tolerance about this ? Or will we need to go to Bunnings later and get a rubber strip to attach to the bottom of the door ? Metricon Liberty 45, Ryde NSW http://forum.homeone.com.au/viewtopic.php?t=82846 Build thread: Metricon Liberty 45 in Ryde, NSW Re: Metricon Liberty 45 in Ryde NSW 530Mar 01, 2018 7:59 am That looks a bit ridiculous, you'd have rain coming in under that door. Re: Metricon Liberty 45 in Ryde NSW 531Mar 01, 2018 9:24 am Quirmeball1280 Hi all, as we are nearing practical completion, we noticed quite a bit of a gap (around 3cm) under our laundry door. Has anyone had any issues with gaps under doors? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ We’re a bit worried about this gap cause the door leads outside. Is there some standard or allowable tolerance about this ? Or will we need to go to Bunnings later and get a rubber strip to attach to the bottom of the door ? Metricon Liberty 45, Ryde NSW http://forum.homeone.com.au/viewtopic.php?t=82846 I'd say thats a temporary door for lockup, there is no way that they will have a gap that large under a door haha Re: Metricon Liberty 45 in Ryde NSW 532Mar 01, 2018 10:59 am Skcel Quirmeball1280 Hi all, as we are nearing practical completion, we noticed quite a bit of a gap (around 3cm) under our laundry door. Has anyone had any issues with gaps under doors? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ We’re a bit worried about this gap cause the door leads outside. Is there some standard or allowable tolerance about this ? Or will we need to go to Bunnings later and get a rubber strip to attach to the bottom of the door ? Metricon Liberty 45, Ryde NSW http://forum.homeone.com.au/viewtopic.php?t=82846 I'd say thats a temporary door for lockup, there is no way that they will have a gap that large under a door haha You would be surprised I recon this is the door that will stay as it is and they will make every effort to adjust surrounded door frame and make every excuse not to chage it. Start complaining early !!! Building with Metricon Liberty 45 Vogue on Sydney Northern Beaches https://forum.homeone.com.au/viewtopic.php?f=31&t=88438 Metricon Liberty 45 in Ryde NSW 533Mar 01, 2018 1:31 pm Thanks all, we’re close to practical completion so want to do everything we can to fix any material issues that are visually obvious before the practical completion inspection and handover Metricon Liberty 45, Ryde NSW http://forum.homeone.com.au/viewtopic.php?t=82846 Build thread: Metricon Liberty 45 in Ryde, NSW Re: Metricon Liberty 45 in Ryde NSW 534Mar 01, 2018 4:10 pm External opening (doors and windows) are supposed to be weather sealed. In laundry, I have an aluminium and rubber strip on the floor which seals the opening when the door is closed. That way rain (or insects) can’t come in. Photo of my door below. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ NabeelC | Metricon Merricks 38 | https://forum.homeone.com.au/viewtopic.php?f=31&t=86276 Re: Metricon Liberty 45 in Ryde NSW 536Mar 01, 2018 5:36 pm Thanks Renman and Nabeelc, hope they also put that seal on our laundry door Metricon Liberty 45, Ryde NSW http://forum.homeone.com.au/viewtopic.php?t=82846 Build thread: Metricon Liberty 45 in Ryde, NSW Re: Metricon Liberty 45 in Ryde NSW 537Mar 02, 2018 6:29 am Yay to scaffolding and safety fencing going! It feels less like a construction site now Hopefully, we are getting close to completing our build Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ The front balcony cladding still needs to be painted so looks a bit out of place at the moment Metricon Liberty 45, Ryde NSW http://forum.homeone.com.au/viewtopic.php?t=82846 Build thread: Metricon Liberty 45 in Ryde, NSW Re: Metricon Liberty 45 in Ryde NSW 538Mar 08, 2018 7:29 pm So we drove past to check out the place and the inside looks cleaned which is good Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ And the rangehood is in too. The only thing is that we had told M we were installing all appliances including rangehood after handover cause we are buying our own.. Metricon Liberty 45, Ryde NSW http://forum.homeone.com.au/viewtopic.php?t=82846 Build thread: Metricon Liberty 45 in Ryde, NSW Re: Metricon Liberty 45 in Ryde NSW 539Mar 08, 2018 7:39 pm Quirmeball1280 So we drove past to check out the place and the inside looks cleaned which is good Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ And the rangehood is in too. The only thing is that we had told M we were installing all appliances including rangehood after handover cause we are buying our own.. Metricon Liberty 45, Ryde NSW http://forum.homeone.com.au/viewtopic.php?t=82846 looks very good. You did not have any major issues in your build, is that right? sorry, if I am asking again did you have all stage private inspection? 3 6526 Hi, First of all, thank you to this community for sharing your thoughts and opinions. We are in early days of our pre-contract stage for Metricon Doulton and we are… 0 11484 Hello All 🙂 We are planning to start our journey of construction our first home. We zeroed down on Metricon and henley homes based on design suitable for our lot and… 0 8901 |
