Browse Forums Building A New House Re: Metricon Liberty 45 in Ryde NSW 381Sep 22, 2017 11:28 am Need you to break into there Q! I want to see some internal pics!!! =P Re: Metricon Liberty 45 in Ryde NSW 382Sep 30, 2017 5:20 pm We dropped by the house today but since we haven’t received our lock up invoice, we knew there was still the side garage metal roof yet to be done. (Can’t really ‘lock up’ if there is still a big hole in the garage roofing) Our front balcony door has finally been installed which is a good sign that the balcony area is being done. There’s also some colorbond cladding onsite which should go on the outside of the balcony facade. Hopefully after that, our scaffolding will come off and we can start some interior work Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Metricon Liberty 45, Ryde NSW http://forum.homeone.com.au/viewtopic.php?t=82846 Build thread: Metricon Liberty 45 in Ryde, NSW Metricon Liberty 45 in Ryde NSW 384Oct 08, 2017 11:07 am If we didn’t look closely enough, we wouldn’t have noticed any work being done this week: Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ The colour bond roofing above part of the garage and the capping on the edges of the facades are done - expecting to get the lock up invoice from M soon In the meantime, we started looking at blinds and got a quote from Luxaflex which was quite high but cheaper than Lovelight through M. Given a limited budget, we’re thinking of going for simple rollers but even they are expensive (especially the sunscreens). We did like the colours though: Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Metricon Liberty 45, Ryde NSW http://forum.homeone.com.au/viewtopic.php?t=82846 Build thread: Metricon Liberty 45 in Ryde, NSW Re: Metricon Liberty 45 in Ryde NSW 387Oct 08, 2017 11:52 am Orpheus I like pebble colour Orph the pebble is a see through screen. Usually that goes on first then the other on top for blockout. viewtopic.php?t=86597 Re: Metricon Liberty 45 in Ryde NSW 388Oct 08, 2017 12:19 pm It’s looking fantastic QM. Geez it’s a difference is speed between brick and hebel build isn’t! My KDR Metricon Hampshire - Liberty - 45 Melb https://r.tapatalk.com/shareLink?share_ ... are_type=t Re: Metricon Liberty 45 in Ryde NSW 390Oct 08, 2017 2:14 pm dulie Still no trips inside yet? Don’t get her into trouble Dulie. My KDR Metricon Hampshire - Liberty - 45 Melb https://r.tapatalk.com/shareLink?share_ ... are_type=t Re: Metricon Liberty 45 in Ryde NSW 391Oct 08, 2017 3:40 pm Haha, been so busy at work that by the time I get to visit, it’s dark already. (Guess I could slip in on weekends but have to climb over my own fence) But will definitely want a site visit pre-lining, and after the insulation is in (but before gyprocking). Metricon Liberty 45, Ryde NSW http://forum.homeone.com.au/viewtopic.php?t=82846 Build thread: Metricon Liberty 45 in Ryde, NSW Metricon Liberty 45 in Ryde NSW 392Oct 15, 2017 6:27 pm We received our lock up invoice this week so looking forward to M finally starting on the inside The house hasn’t changed much from the outside. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ But something we noticed was that the holes in the bricks are showing in the slopped bricks they use under the windows. Not really sure how to get rid of the hole look though Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Overall the house build seems to be going well. The independent inspector went on Friday to do the pre-lining inspection so we will know the results early this week. It will be interesting once the front pylons are rendered and cladding in the front balcony goes in as to whether we picked the right colour combos. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Something we noticed was that we should have got brick in-fills above the front balcony door. We had provisioned for this for the stacker doors in the family and dining rooms but forgot about that one Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Metricon Liberty 45, Ryde NSW http://forum.homeone.com.au/viewtopic.php?t=82846 Build thread: Metricon Liberty 45 in Ryde, NSW Re: Metricon Liberty 45 in Ryde NSW 393Oct 15, 2017 7:13 pm Bugger about the missed brick in fill. Doesn't matter how much you plan, there's always something that gets missed. =( Re: Metricon Liberty 45 in Ryde NSW 395Oct 15, 2017 7:54 pm Quirmeball1280 We received our lock up invoice this week so looking forward to M finally starting on the inside The house hasn’t changed much from the outside. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ But something we noticed was that the holes in the bricks are showing in the slopped bricks they use under the windows. Not really sure how to get rid of the hole look though Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Overall the house build seems to be going well. The independent inspector went on Friday to do the pre-lining inspection so we will know the results early this week. It will be interesting once the front pylons are rendered and cladding in the front balcony goes in as to whether we picked the right colour combos. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Something we noticed was that we should have got brick in-fills above the front balcony door. We had provisioned for this for the stacker doors in the family and dining rooms but forgot about that one Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Metricon Liberty 45, Ryde NSW http://forum.homeone.com.au/viewtopic.php?t=82846 do you have brick infill picture, just want to see the difference. I don't think we did this. Re: Metricon Liberty 45 in Ryde NSW 396Oct 15, 2017 7:54 pm Quirmeball1280 We received our lock up invoice this week so looking forward to M finally starting on the inside The house hasn’t changed much from the outside. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ But something we noticed was that the holes in the bricks are showing in the slopped bricks they use under the windows. Not really sure how to get rid of the hole look though Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Overall the house build seems to be going well. The independent inspector went on Friday to do the pre-lining inspection so we will know the results early this week. It will be interesting once the front pylons are rendered and cladding in the front balcony goes in as to whether we picked the right colour combos. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Something we noticed was that we should have got brick in-fills above the front balcony door. We had provisioned for this for the stacker doors in the family and dining rooms but forgot about that one Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Metricon Liberty 45, Ryde NSW http://forum.homeone.com.au/viewtopic.php?t=82846 do you have brick infill picture, just want to see the difference. I don't think we did this. Re: Metricon Liberty 45 in Ryde NSW 397Oct 15, 2017 8:45 pm Have noticed that brick infill seems to be an ongoing issue with brick builds. My KDR Metricon Hampshire - Liberty - 45 Melb https://r.tapatalk.com/shareLink?share_ ... are_type=t Metricon Liberty 45 in Ryde NSW 398Oct 16, 2017 10:29 pm Yeah, the brick infills thing is easy to miss until it’s too late. I’ve been told that they won’t do brick infills unless they can lay at least three rows of bricks between the ceiling and the window/stacker door. The other thing we could have done (but now it’s too late for us) is to have taller stacker doors. When we raised the height of our first floor we forgot to raise the height of the stacker door as well Kandi, a stacker door without brick infills looks like this: Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ (See the part above the stacker door and eaves.) If there are brick infills, then it would look like this: Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ (See the rows of bricks above the space where the stacker doors will go.) Another example where there are brick infills above dining room windows: Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Yay! I finally got access to site today - first time since the build started. Will post some more pics when I sort out which photos are which (cause they seem to all look the same inside) Metricon Liberty 45, Ryde NSW http://forum.homeone.com.au/viewtopic.php?t=82846 Build thread: Metricon Liberty 45 in Ryde, NSW Re: Metricon Liberty 45 in Ryde NSW 399Oct 17, 2017 11:07 am Must have been awesome to finally get to stroll around the house for the first time! Re: Metricon Liberty 45 in Ryde NSW 400Oct 17, 2017 9:58 pm So we finally went on site earlier this week and it looks like some work has been done on the inside (plumbing, electrical, insulation) even though the outside pretty much looked the same for the last 4 weeks Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Hopefully the plasterboard should be put in this week which will be nice. We were told that a critical point is when the stairs are constructed cause once that is in, the waterproofers can come in to do the wet areas upstairs and downstairs Metricon Liberty 45, Ryde NSW http://forum.homeone.com.au/viewtopic.php?t=82846 Build thread: Metricon Liberty 45 in Ryde, NSW 3 6402 Hi, First of all, thank you to this community for sharing your thoughts and opinions. We are in early days of our pre-contract stage for Metricon Doulton and we are… 0 10733 Hello All 🙂 We are planning to start our journey of construction our first home. We zeroed down on Metricon and henley homes based on design suitable for our lot and… 0 8179 |
