Browse Forums Building A New House Metricon Liberty 45 in Ryde NSW 401Oct 17, 2017 11:22 pm The long awaited internal spam pics Fantastic to see the internal progress. Were you emotional seeing the inside after all this time? Re: Metricon Liberty 45 in Ryde NSW 402Oct 18, 2017 7:00 am Renman The long awaited internal spam pics Fantastic to see the internal progress. Were you emotional seeing the inside after all this time? Hi Renman, I think we had mixed emotions - excited cause it’s progressed so far from initial slab, but also a little underwhelmed because you see all the insides which consist of uncleaned brick, cables, puffy insulation, and broken windows. Naively, we still had images of the Metricon display homes in our head Metricon Liberty 45, Ryde NSW http://forum.homeone.com.au/viewtopic.php?t=82846 Build thread: Metricon Liberty 45 in Ryde, NSW Re: Metricon Liberty 45 in Ryde NSW 403Oct 18, 2017 9:27 am Our site was not keep very clean as well as the bulk of the work was done during the week winter months. Main thing to look out for is that they have provision all the correct number of cabling, door sizes/heights are correct, gaps between the windows and frames are not too wide apart, you should have any broken windows if they are missing some glass is because they installed them at a later date. This is so that the window frame can be light enough for them to install. Re: Metricon Liberty 45 in Ryde NSW 404Oct 18, 2017 11:26 am Looking good Q! Hopefully things continue to progress and no more delays! Re: Metricon Liberty 45 in Ryde NSW 405Oct 19, 2017 4:54 pm Quirmeball1280 Yeah, the brick infills thing is easy to miss until it’s too late. I’ve been told that they won’t do brick infills unless they can lay at least three rows of bricks between the ceiling and the window/stacker door. The other thing we could have done (but now it’s too late for us) is to have taller stacker doors. When we raised the height of our first floor we forgot to raise the height of the stacker door as well Kandi, a stacker door without brick infills looks like this: Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ (See the part above the stacker door and eaves.) If there are brick infills, then it would look like this: Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ (See the rows of bricks above the space where the stacker doors will go.) Another example where there are brick infills above dining room windows: Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Yay! I finally got access to site today - first time since the build started. Will post some more pics when I sort out which photos are which (cause they seem to all look the same inside) Metricon Liberty 45, Ryde NSW http://forum.homeone.com.au/viewtopic.php?t=82846 Thanks Quirme for explaining. not sure its too late. we are waiting for council approval. I can as the CSC. Do you have to do this for all the external windows and doors?. our ground floor is 2700. 1st floor is 2400. Re: Metricon Liberty 45 in Ryde NSW 406Oct 19, 2017 5:37 pm Did anyone did the island bench top after hand over. I need some advise please. M quoted our island bench CAT 6 22,000. pacific stone quoted 10,600. so I am thinking if its not complicated then we could do after. Re: Metricon Liberty 45 in Ryde NSW 407Oct 19, 2017 6:33 pm Kandi Quirmeball1280 Yeah, the brick infills thing is easy to miss until it’s too late. I’ve been told that they won’t do brick infills unless they can lay at least three rows of bricks between the ceiling and the window/stacker door. The other thing we could have done (but now it’s too late for us) is to have taller stacker doors. When we raised the height of our first floor we forgot to raise the height of the stacker door as well Kandi, a stacker door without brick infills looks like this: Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ (See the part above the stacker door and eaves.) If there are brick infills, then it would look like this: Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ (See the rows of bricks above the space where the stacker doors will go.) Another example where there are brick infills above dining room windows: Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Yay! I finally got access to site today - first time since the build started. Will post some more pics when I sort out which photos are which (cause they seem to all look the same inside) Metricon Liberty 45, Ryde NSW http://forum.homeone.com.au/viewtopic.php?t=82846 Thanks Quirme for explaining. not sure its too late. we are waiting for council approval. I can as the CSC. Do you have to do this for all the external windows and doors?. our ground floor is 2700. 1st floor is 2400. Brick infill is some thing for the look, or its for any other important reason? Re: Metricon Liberty 45 in Ryde NSW 408Oct 20, 2017 6:56 am Kandi Thanks Quirme for explaining. not sure its too late. we are waiting for council approval. I can as the CSC. Do you have to do this for all the external windows and doors?. our ground floor is 2700. 1st floor is 2400. We mentioned to the consultant that we wanted all brick infills but our contract item only made mention of the bits above the family room windows and ground floor stacker doors. Having said that, you should double check with M any ground floor windows, garage door and any other doors to the outside (eg stacker doors) that are just below roofing, as well as any windows or stacker doors on the first floor that do not meet the eaves. If the window/door is too close to the eaves to put 2-3 rows of bricks infills then M can still use it’s normal (non brick) infills. Metricon Liberty 45, Ryde NSW http://forum.homeone.com.au/viewtopic.php?t=82846 Build thread: Metricon Liberty 45 in Ryde, NSW Re: Metricon Liberty 45 in Ryde NSW 409Oct 20, 2017 7:06 am For our house, all downstairs windows and doors were already brick infill, except the front door and garage, which we upgraded. It will tell you on the plans anyway. Re: Metricon Liberty 45 in Ryde NSW 410Oct 21, 2017 6:38 am blackcat20 For our house, all downstairs windows and doors were already brick infill, except the front door and garage, which we upgraded. It will tell you on the plans anyway. Re: Metricon Liberty 45 in Ryde NSW 411Oct 26, 2017 11:46 am It needs steel beam for brick infill but not lightweight infill. If it doesn't come with the facade design, M will charge extra. We opt for brick infill for all the windows/door where applicable, had the wording on contract, signed the contract, M came back said estimator missed to cost one beam, they need to back charge us..... Re: Metricon Liberty 45 in Ryde NSW 412Oct 26, 2017 12:24 pm The upgrade to brick for the garage was $1200 for us. Re: Metricon Liberty 45 in Ryde NSW 413Nov 06, 2017 4:13 am Quirmeball1280 Hello everyone, We have finally signed a contract with M It has been quite a stressful 4 weeks as during this time we had to: - review and finalise the contract terms; - update site plans with some final changes; and - update contract items due to some oversights from M (not unexpected though). There were a few key issues we had to resolve with M, it maybe something that you might come across too: (Windows facing the back of the house) We wanted the bedroom windows on the first floor facing the back of the house so they would have a nice view of the garden rather than the neighbours' houses on each side of the house. In the end, there was a lot more work than expected to make this happen - decreasing the angle of the roofline, reducing the size of the eaves, increasing the height of the first floor. So its good to ask specifically whether your plan can accommodate this, even if your sales consultant draws it into your plans. (Garage setback) Our council required the garage to be setback 1m behind the main house setback. We only found out when the plans were drawn up for the contract so we had to make a decision whether (a) incur additional cost to extend the front of the main house, or (b) reduce the length of the garage. If you are going through council, be prepared for these council requirement quirks. We'll keep you all posted once we have final drawings. But now it's onto the Studio M appointment to finalise externals.. and undoubtedly there will be eye-watering decorations with an "upgrade" price tag attached to all of it Hi do you mind sharing your experience with the 1m garage set back? We noticed that in our plans at tender. How did you overcome this? Re: Metricon Liberty 45 in Ryde NSW 414Nov 06, 2017 2:27 pm Vet Quirmeball1280 Hello everyone, We have finally signed a contract with M It has been quite a stressful 4 weeks as during this time we had to: - review and finalise the contract terms; - update site plans with some final changes; and - update contract items due to some oversights from M (not unexpected though). There were a few key issues we had to resolve with M, it maybe something that you might come across too: (Windows facing the back of the house) We wanted the bedroom windows on the first floor facing the back of the house so they would have a nice view of the garden rather than the neighbours' houses on each side of the house. In the end, there was a lot more work than expected to make this happen - decreasing the angle of the roofline, reducing the size of the eaves, increasing the height of the first floor. So its good to ask specifically whether your plan can accommodate this, even if your sales consultant draws it into your plans. (Garage setback) Our council required the garage to be setback 1m behind the main house setback. We only found out when the plans were drawn up for the contract so we had to make a decision whether (a) incur additional cost to extend the front of the main house, or (b) reduce the length of the garage. If you are going through council, be prepared for these council requirement quirks. We'll keep you all posted once we have final drawings. But now it's onto the Studio M appointment to finalise externals.. and undoubtedly there will be eye-watering decorations with an "upgrade" price tag attached to all of it Hi do you mind sharing your experience with the 1m garage set back? We noticed that in our plans at tender. How did you overcome this? Hi Vet, We just worked with the consultant to get the price impact on the 2 options: 1) reduce the size of the garage and other bits to accomodate the Council requirements, or 2) extend the house and portico side out so it is 1m set back for the garage. We opted for Option 2 after checking that we still met the council floor space ratio for our site. The cost for us was an extra $3,000. Metricon Liberty 45, Ryde NSW http://forum.homeone.com.au/viewtopic.php?t=82846 Build thread: Metricon Liberty 45 in Ryde, NSW Re: Metricon Liberty 45 in Ryde NSW 415Nov 06, 2017 7:20 pm Quirmeball1280 Vet Quirmeball1280 Hello everyone, We have finally signed a contract with M It has been quite a stressful 4 weeks as during this time we had to: - review and finalise the contract terms; - update site plans with some final changes; and - update contract items due to some oversights from M (not unexpected though). There were a few key issues we had to resolve with M, it maybe something that you might come across too: (Windows facing the back of the house) We wanted the bedroom windows on the first floor facing the back of the house so they would have a nice view of the garden rather than the neighbours' houses on each side of the house. In the end, there was a lot more work than expected to make this happen - decreasing the angle of the roofline, reducing the size of the eaves, increasing the height of the first floor. So its good to ask specifically whether your plan can accommodate this, even if your sales consultant draws it into your plans. (Garage setback) Our council required the garage to be setback 1m behind the main house setback. We only found out when the plans were drawn up for the contract so we had to make a decision whether (a) incur additional cost to extend the front of the main house, or (b) reduce the length of the garage. If you are going through council, be prepared for these council requirement quirks. We'll keep you all posted once we have final drawings. But now it's onto the Studio M appointment to finalise externals.. and undoubtedly there will be eye-watering decorations with an "upgrade" price tag attached to all of it Hi do you mind sharing your experience with the 1m garage set back? We noticed that in our plans at tender. How did you overcome this? Hi Vet, We just worked with the consultant to get the price impact on the 2 options: 1) reduce the size of the garage and other bits to accomodate the Council requirements, or 2) extend the house and portico side out so it is 1m set back for the garage. We opted for Option 2 after checking that we still met the council floor space ratio for our site. The cost for us was an extra $3,000. Metricon Liberty 45, Ryde NSW http://forum.homeone.com.au/viewtopic.php?t=82846 Thanks Metricon Liberty 45, Ryde NSW. We were also thinking of that option too extend the portico. However I am pretty sure we would have exceeded the floor space ratio. If you go through Council for the DA what's there chances in allowing you to exceed the floor space ratio? I have requested another meeting with Metricon this week to discus this Re: Metricon Liberty 45 in Ryde NSW 416Nov 06, 2017 9:15 pm Hi vet Portico , void , staircases and alfresco are excluded from FSR caculations. Re: Metricon Liberty 45 in Ryde NSW 417Nov 06, 2017 9:37 pm Mojitostan Hi vet Portico , void , staircases and alfresco are excluded from FSR caculations. Mojitostan is right. However, you may wish to extend your inside space so that it pushes the portico out creating the 1m setback for the garage. It really depends on how your facade works with your portico and garage. If you look at our plans, you’ll see that the front door and guest room side (and upstairs) has been extended out a bit more than the garage side so that the portico ends up being further out relative to the garage. Your M consultant should be able to help with this. Metricon Liberty 45, Ryde NSW http://forum.homeone.com.au/viewtopic.php?t=82846 Build thread: Metricon Liberty 45 in Ryde, NSW Metricon Liberty 45 in Ryde NSW 418Nov 06, 2017 9:52 pm Vet Quirmeball1280 (Garage setback) Our council required the garage to be setback 1m behind the main house setback. We only found out when the plans were drawn up for the contract so we had to make a decision whether (a) incur additional cost to extend the front of the main house, or (b) reduce the length of the garage. If you are going through council, be prepared for these council requirement quirks. Hi do you mind sharing your experience with the 1m garage set back? We noticed that in our plans at tender. How did you overcome this? Hi Vet, actually I just checked our contract, we ended up extending the non garage side a bit and reducing the garage a bit to make up the 1m setback. In addition to the $3k for extending the walls and roofline for the upstairs and downstairs (which included a credit for reducing the garage), we had to pay another $3k extending the concrete slab Metricon Liberty 45, Ryde NSW http://forum.homeone.com.au/viewtopic.php?t=82846 Build thread: Metricon Liberty 45 in Ryde, NSW Re: Metricon Liberty 45 in Ryde NSW 419Nov 07, 2017 5:43 pm Need help to decide Vanity heights Please In our plan we have a vanity height of 865m, which is a good height. In Kitchen culture drawing they have change it to 805mm. I have ask the kitchen consultant she is saying since we having above counter basin AXA 600, they have reduced the height. If you have above counter basin can you please check or post your vanity pictures. I want to make sure, and get the right height. All of your inputs and thoughts will help me to make the decision. Thanks, Re: Metricon Liberty 45 in Ryde NSW 420Nov 07, 2017 6:21 pm Kandi Need help to decide Vanity heights Please In our plan we have a vanity height of 865m, which is a good height. In Kitchen culture drawing they have change it to 805mm. I have ask the kitchen consultant she is saying since we having above counter basin AXA 600, they have reduced the height. If you have above counter basin can you please check or post your vanity pictures. I want to make sure, and get the right height. All of your inputs and thoughts will help me to make the decision. Thanks, My above counter has meant my drawings were reduced to 770. I measured it with my husband and we are happy with it because it would be ridiculously high with our above counter basin. Metricon Vantage https://r.tapatalk.com/shareLink?share_ ... are_type=t 3 6389 Hi, First of all, thank you to this community for sharing your thoughts and opinions. We are in early days of our pre-contract stage for Metricon Doulton and we are… 0 10715 Hello All 🙂 We are planning to start our journey of construction our first home. We zeroed down on Metricon and henley homes based on design suitable for our lot and… 0 8157 |
