Browse Forums Building A New House 1 Jul 28, 2008 11:26 am Hi All,
Our planned house will be cut into a cliff . It is plalnned to be a concrete slab full brick 1st floor and concrete slab b/veneer 2nd floor sitting above the retaining wall. There is a proposed large ventilation space 1-2m wide between cliff retaining wall and the garage and the 1 bedroom ground floor which is adjacent to the cliff There will be a solar ventilating fan and drainage in the ventilation space . The builder says this is plenty of provision to keep dry We live in a hundred year old damp mouldy house now and my wife hates it and is paranoid about damp and mould A friend recommended we should ask the builder to suspend the ground floor slab ( sounds expensive though). Is this needed??? Do any of the newer chemicals or additives which can be added to concrete work well as this may be a cheaper option if so Many thanks for any advice Mike Mike 2/3 of the way thru the build Re: concrete slab waterproofing 2Jul 30, 2008 1:31 pm Hi Mike,
I can't really help, but I am also interested in this as we are building into the side of a hill, using an existing 'quarry'. There will be some further excavation, but not much. Looking at our plans I don't think we have anywhere near that sort of space at the back, and the designer hasn't mentioned anything about suspending the slab. This is one of those areas that I've just thought 'He'll know what he is doing'...most probably not a good attitude to have. I'll have to follow this up. May be one of our engineering type members might have more of an idea of what is required. 'chelle We have a hand-over date...15/10...but I won't hold my breath! http://people-in-glass-houses.blogspot.com/ Re: concrete slab waterproofing 3Aug 01, 2008 12:07 pm Hi 'chelle
You do need a ventilation gap with fan (solar is popular) everyone tells me that It does look like he has made reasonable provision with a lot of drainage into stormwater before it reaches the true wall of the house and he saws this is probably more than we would ever need. The worry is what if he is not correct. You can suspend the slab but this is significantly expensive and possibly not needed. concrete is porous and does soak moisture, there are some additives which reduce concretes porosity and thats what were wondering about. Builder says 'look dont worry about it you dont need that " Very hard to rectify once done incorrectly though thats the worry Mike 2/3 of the way thru the build Hey There. No problems re jumping in. My original question was "should I have waterproofed" the concrete slab before putting batons down. We have been told we should… 7 4472 I have researched this topic in detail recently but for another state which has no licensing requirements at all so any handy man can waterproof any old way and not have… 1 8514 2 8685 |
