Browse Forums Building A New House Re: Photoshop Help Please ! ! ! 122Aug 10, 2008 10:14 pm Peter,
Above the garage door, above windows, etc they often have fibre cement infills up to the eaves or fascia. For M3tricon in Vic it is an upgrade to make it brick over the windows. Brick over the garage door is dependant on which design chosen. I just personally prefer the look of all brick. It works out about $100 per metre of window width. For our house it's approx $2400 from memory. Over the garage is more complicated apparently and more expensive. I'm expecting $800 - $1000 for over the rear garage door which is 2400mm. Check your standard inclusions though Peter as I've noticed a few things differ from Vic to QLD with M3tricon so if you're lucky you may already have them. Jo I leave you to fend for yourself, figure things out yourself. Terrence Malick Thankyou so much 😀 I've decided on White on white for doors and trims, White on white 50% on ceiling and Mt buller for walls. Fingers crossed it will look OK 😀 2 7143 i had the my concreters concrete right up to the fence. I have pits all along my path, so the water tends to drain away from the house and into the pits. There's only one… 7 12718 All 3 items listed are defects and are of concern. Please seek qualified independent inspector and/or legal advice for your state. 1 8203 |
