Browse Forums Building A New House Re: Benchtop height - from slab or finished floor 2Mar 29, 2016 8:48 pm Custom downslope build Build thread viewtopic.php?f=31&t=61873 Blog http://www.buildingroyalmanor.blogspot.com.au Re: Benchtop height - from slab or finished floor 3Mar 29, 2016 9:11 pm The FFL is the slab.
I would say the builder is in the right. It's not reasonable to expect him to know how high your future flooring will be - e.g. if you're using tiles it'll be thinner than if you were using floating floorboards. So it's reasonable to expect it's 900mm from the slab. However it's pretty poor form from his part to not let you know it's 900mm from the slab - would have taken him literally 3 seconds. A miscommunication from both parties in my opinion - him for not telling and you for not asking. Re: Benchtop height - from slab or finished floor 4Mar 29, 2016 9:16 pm jas0nt The FFL is the slab. I would say the builder is in the right. It's not reasonable to expect him to know how high your future flooring will be - e.g. if you're using tiles it'll be thinner than if you were using floating floorboards. So it's reasonable to expect it's 900mm from the slab. A miscommunication from both parties in my opinion. I suppose this makes sense. Our benches are 900mm high however they sit on top of our flooring (solid timber) so for us the height/thickness of the floor finish didn't come into it. Custom downslope build Build thread viewtopic.php?f=31&t=61873 Blog http://www.buildingroyalmanor.blogspot.com.au Re: Benchtop height - from slab or finished floor 5Mar 29, 2016 9:35 pm jas0nt The FFL is the slab. I would say the builder is in the right. It's not reasonable to expect him to know how high your future flooring will be - e.g. if you're using tiles it'll be thinner than if you were using floating floorboards. So it's reasonable to expect it's 900mm from the slab. However it's pretty poor form from his part to not let you know it's 900mm from the slab - would have taken him literally 3 seconds. A miscommunication from both parties in my opinion - him for not telling and you for not asking. Very helpful info this, gives me a better understanding of this for future reference. Re: Benchtop height - from slab or finished floor 7Mar 30, 2016 11:00 am Any decent builder would install the flooring first, do a rough sand then install the kitchen. It is more expensive though as you then have to lay tarps etc down to protect the floor. The project homes guys go the cheaper route. Did your builder know you were having timber flooring in the kitchen? Stewie Re: Benchtop height - from slab or finished floor 8Mar 30, 2016 11:37 am Yes we are building with a project builder who knows our entire plans as they are doing the build end to end! Re: Benchtop height - from slab or finished floor 9Mar 30, 2016 4:00 pm Ours is from slab level too unfortunately M Y C U S T O M C O R A L B R O N T E 43 ...............Kitchen! 16 Nov 2016 https://forum.homeone.com.au/viewtopic.php?f=31&t=79581 interesting situation what happened after builder issued final invoice? did you list as defect or not does the building surveyor have any responsibility? ie. issuing… 13 46966 Building Standards; Getting It Right! Hi all, My neighbour has built his 15m long garage on our boundary. It was agreed as part of the planning permit that the wall must be in exposed recycled brick. For some… 0 10914 Hi, I contracted a Builder to do a Garage to Bedroom + ensuite conversion (Class 1a), the Builder engaged the Certifier and Engineer and received BDA from the Certifier… 0 5033 |
