Browse Forums Building A New House Re: Advice on pool size and placement please 6Mar 28, 2016 12:27 am Recently moved to a 60's home in need of some improvement! http://s797.photobucket.com/user/leenii ... ch%20House Old house: http://s797.photobucket.com/albums/yy25 ... loo/House/ Re: Advice on pool size and placement please 7Mar 28, 2016 1:48 am You still have a decent size area to put a pool despite the sewer line. Teenagers, unlike young children, need a bigger pool. Children wants a splash and thats it. So I would go at least 6-8 metre length and if you can stretch the budget then go for 8m Width, I would go for 3 metres. This will give you a nice space on both sides to put a sun bed and for the children to run around. I would also put it infront of the alfresco as close to Lot 56. So when you are chilling in the alfresco you will also be next to the pool and also view the pool from the living. The other point is if you add a sliding door in your master you can access the pool directly without having to go through the house. So 8x3 as close to lot 56 as possible. Goodluck Hi all, My first post, we are building a house and can’t decide the layout of the lounge room. We have a large N/W facing window and are wanting to have a wood slow… 0 13724 Move your linen into laundry and access laundry from your present linen space 1 8007 Versaloc is a mortarless besser block system that still needs a properly engineered footing. If you just do a 400x200 footing it will fail in time. At 17m long you need it… 1 17340 |
