Browse Forums Building A New House 1 Mar 09, 2016 9:53 pm Hi All, I've mainly been lurking in this forum reading all the new build threads. Thanks for sharing.
We are now going into the planning stage and finalising plans and elevations. I would appreciate advice on our windows especially in terms of ventilation. The architect has just made them the maximum size as we can reduce them after the DA is approved. Our block faces north. It is only 12.1 by 45m and slopes upward to the South and to the west. We have views to the NE/E. Thank you everyone. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Custom kdr in Sydney - Narrow Block with front facing No 2Mar 09, 2016 10:10 pm Can you post better pics? Re: Custom kdr in Sydney - Narrow Block with front facing No 3Mar 10, 2016 3:47 am Looks like you have quite a lot of W facing glazing. I'd be trying the eliminate/minimize these windows, as they will let in a lot of heat in summertime. The same can be said for E facing windows (though it's hotter in the afternoon, when W facing glazing is in sunlight). Re: Custom kdr in Sydney - Narrow Block with front facing No 4Mar 10, 2016 7:48 am The upstairs west Windows are more for air circulation. I will remove the west Windows in the master bedroom as that already has enough light facing North. The tall louvres in the WIR are for light and circulation. Those can be made shorter or removed as well. Last room is the bathroom and that window will be a high window. Downstairs west has the garage, mud room, laundry, pantry, kitchen and dining. Mud and laundry will have doors with windows. The pantry window is for light and ventilation as that is south west. Next window is the kitchen splash back and will face a green wall. I'll remove the west dining room Windows as there are enough skylights at the back. Cooling breezes blow in from S/SE. Custom kdr in Sydney - Narrow Block with front facing North 6Mar 10, 2016 11:02 am I would change a few things but just working off what you have. If it was my house I would orientate my private open space to the east. Maximise by building on the western boundary, add skillion roof to the rear either facing east, etc
Re: Custom kdr in Sydney - Narrow Block with front facing No 9Mar 10, 2016 1:28 pm I would also suggest putting a void in the entry as soon as you walk in, I would also adjust the rooms upstairs to maximize space and make them flow better Re: Custom kdr in Sydney - Narrow Block with front facing No 14Mar 11, 2016 12:18 pm I like the courtyard area giving the northern windows into the living space. Have you checked the roof overhang of Bed 2 doesn't shadow this too much in winter? I'm a bit doubtful about the value of the void. Being half over the pantry and seeing as it makes thermal containment between the floors more difficult, I'd think about putting the stairs where the laundry is, and remove that extra bit of 2-storey section to try to save some money. In the WIR, I'd probably run straight hanging/shelving rather than the U-shaped unit shown. The U-shape gives a little bit extra volume, but you lose more to poor access in the corners than you gain by the extra edges. I'd also put a door between the WIR and the master bedroom. If your area has mosquitoes, flies or other airborne wildlife that you don't want inside, then make sure that the type of external doors you specify to the living area can have practical insect screens on them, or have some way of screening off the outdoor area. Otherwise you'll find you're limited in how you can use them for ventilation. Before going to a double basin in the bathroom, or separated bath, I'd be trying to get a separate toilet. There doesn't appear to be provision marked for air-conditioning ducts between the floors. If you're looking at ducted air-conditioning, you should think about where they will go. The garage is rather small for a double. If you put two cars in, it'll be a squeeze to get much else in as well. Re: Custom kdr in Sydney - Narrow Block with front facing No 15Mar 16, 2016 8:10 pm Thanks for the feedback oneJohn. And Thanks for picking up on the void error. We've removed the long bridge and made the void larger and pushed out the landing. I wanted a loft mezzanine but I couldn't afford the full double height so the void is a compromise. It'll probably revise the WIR later when I see the actual space. Same with the bathrooms. It's a small double garage because of bedroom 4. a double garage is a rare commodity on my street. The warning is on the sticker on the door too. Second the aluminium powdercoat 6 18204 So it looks like we finally have some movement on site! Definitely later than expected, but I'll take any progress at this point. I'll drop by over the weekend to get… 5 27737 dimensions on your original plan are inconsistent and with accurate dimensions (including site plan, upstairs and down) i could make a proper scale drawing with furniture… 3 7521 |
