Browse Forums Building A New House 1 Mar 06, 2016 7:29 pm Re: Why would a draftsman dedign this? 2Mar 06, 2016 7:50 pm I can only think that the drafty thought(or was told) it was a solar panel with a hot water tank on the ground rather than at the top of the panel. The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Why would a draftsman dedign this? 3Mar 06, 2016 7:52 pm bashworth I can only think that the drafty thought(or was told) it was a solar panel with a hot water tank on the ground rather than at the top of the panel. On the plans its just says HWS on the ground level but im not sure how that translates to real life placement of the tank. Re: Why would a draftsman dedign this? 4Mar 06, 2016 9:06 pm firsthomebuy bashworth I can only think that the drafty thought(or was told) it was a solar panel with a hot water tank on the ground rather than at the top of the panel. On the plans its just says HWS on the ground level but im not sure how that translates to real life placement of the tank. That indicates to me that the drafty was originally told the hot water tank would be on the ground and the panel location would be fine. The scenario is thus: After the drawing was finished someone decided they wanted a different solar hot water system. No one asked the drafty to check/ change the drawing to provide a different location. The tradies just installed where the drawing indicated. The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Why would a draftsman dedign this? 5Mar 07, 2016 5:58 am bashworth firsthomebuy bashworth I can only think that the drafty thought(or was told) it was a solar panel with a hot water tank on the ground rather than at the top of the panel. On the plans its just says HWS on the ground level but im not sure how that translates to real life placement of the tank. That indicates to me that the drafty was originally told the hot water tank would be on the ground and the panel location would be fine. The scenario is thus: After the drawing was finished someone decided they wanted a different solar hot water system. No one asked the drafty to check/ change the drawing to provide a different location. The tradies just installed where the drawing indicated. This is where the hot water system is referred to in the plan Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Why would a draftsman dedign this? 6Mar 07, 2016 6:16 am If this is a new home under warranty you may have a case to have builder move the HWS. I once had a case where a lady bought off the plan (units were nearing completion) with a lovely panoramic view of Melbourne from top floor only to have the view subsequently spoiled with large rooftop AC. Developer wasn't going to move it "bad luck". That's when I got involved and was able to prove that AC was on approved plans shown in different location. Guess what? Developer did move it. Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Why would a draftsman dedign this? 7Mar 07, 2016 7:31 am Quote: The scenario is thus: After the drawing was finished someone decided they wanted a different solar hot water system. As per what Bashworth has already asked... did you change your mind about what sort of hot water system you wanted after the plans were drawn ? Stewie Re: Why would a draftsman dedign this? 8Mar 07, 2016 8:01 am Stewie D Quote: The scenario is thus: After the drawing was finished someone decided they wanted a different solar hot water system. As per what Bashworth has already asked... did you change your mind about what sort of hot water system you wanted after the plans were drawn ? Stewie I actually didn't have any say in the plans. I purchased once it was pretty much almost built but the HWS was not yet installed. But from the plans they gave me it didn't indicate it was in direct view of the window That sucks! Hope it all works out. Good to move away from steel anyway for all your reasons, but it's also thermally poor. 16 17871 Hi All, I just wanted to close this topic out with an update. So we ended up agreeing to a number with the insurance company, and after an extensive amount of hand… 8 23401 A Sabco spin mop, minimal moisture, not very regularly. I was told these hybrids are water resistant 🤷♀️ 2 7640 |
