Browse Forums Building A New House 1 Mar 03, 2016 10:16 am I am sure some of you have already considered Hebel flooring for your builds. Can you please advise how much did your builder charge you ? My understanding is that the installers charge $80 per sqm (for install and supply). But are builders being fare when they are quoting you for hebel flooring upgrade in lieu of particle flooring ? Thank you. Re: Hebel flooring ? Costs and benefits analysis 2Jun 07, 2016 2:02 pm SoftEng I am sure some of you have already considered Hebel flooring for your builds. Can you please advise how much did your builder charge you ? My understanding is that the installers charge $80 per sqm (for install and supply). But are builders being fare when they are quoting you for hebel flooring upgrade in lieu of particle flooring ? Thank you. https://edenbrae.wordpress.com/about/marina-43/ 1 6637 1000000% definitely add insulation. I have in my home and it makes a big difference minimising sound transfer. Insulation is pretty cheap and definitely worth it 2 6210 I was looking at different options for a fence for my build and Hebel PowerFence seemed like a good option (one of the criteria was a solid wall look). However, I don't… 0 5906 |
