Browse Forums Building A New House Re: Coral Homes - Modified Bronte 861Dec 18, 2017 7:29 pm Coral build- Modified Bronte 42 - We're in!!! https://forum.homeone.com.au/viewtopic.php?f=31&t=82234&p=1513775&hilit=coral+modified+bronte#p1513775 Re: Coral Homes - Modified Bronte 864Dec 18, 2017 7:38 pm Coral build- Modified Bronte 42 - We're in!!! https://forum.homeone.com.au/viewtopic.php?f=31&t=82234&p=1513775&hilit=coral+modified+bronte#p1513775 Re: Coral Homes - Modified Bronte 866Dec 18, 2017 7:42 pm M Y C U S T O M C O R A L B R O N T E 43 ...............Kitchen! 16 Nov 2016 https://forum.homeone.com.au/viewtopic.php?f=31&t=79581 Re: Coral Homes - Modified Bronte 867Dec 18, 2017 7:46 pm Coral build- Modified Bronte 42 - We're in!!! https://forum.homeone.com.au/viewtopic.php?f=31&t=82234&p=1513775&hilit=coral+modified+bronte#p1513775 Re: Coral Homes - Modified Bronte 870Dec 19, 2017 7:45 am Coral build- Modified Bronte 42 - We're in!!! https://forum.homeone.com.au/viewtopic.php?f=31&t=82234&p=1513775&hilit=coral+modified+bronte#p1513775 Re: Coral Homes - Modified Bronte 872Dec 19, 2017 3:55 pm _________________________ Building the Noosa 26 with Coral Homes https://forum.homeone.com.au/viewtopic.php?f=31&t=80794 Re: Coral Homes - Modified Bronte 873Jan 09, 2018 7:31 pm Coral build- Modified Bronte 42 - We're in!!! https://forum.homeone.com.au/viewtopic.php?f=31&t=82234&p=1513775&hilit=coral+modified+bronte#p1513775 Re: Coral Homes - Modified Bronte 875Jan 10, 2018 6:49 am Coral build- Modified Bronte 42 - We're in!!! https://forum.homeone.com.au/viewtopic.php?f=31&t=82234&p=1513775&hilit=coral+modified+bronte#p1513775 Re: Coral Homes - Modified Bronte 877Jan 11, 2018 4:06 am M Y C U S T O M C O R A L B R O N T E 43 ...............Kitchen! 16 Nov 2016 https://forum.homeone.com.au/viewtopic.php?f=31&t=79581 Re: Coral Homes - Modified Bronte 878Jan 11, 2018 7:10 am Coral build- Modified Bronte 42 - We're in!!! https://forum.homeone.com.au/viewtopic.php?f=31&t=82234&p=1513775&hilit=coral+modified+bronte#p1513775 Re: Coral Homes - Modified Bronte 879Jan 17, 2018 8:52 pm Garage floor has been the target for the last couple of days. Hubby went to Supercheap and bought Rust-oleum for the flooring. Quite happy with the result. The prep work the day before was time consuming but necessary and recommend it. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Primer (was optional but recommend using it). Bought better rollers rather than using the ones in the kit. (Did lots of online research) Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Follow directions to a T recommended too. This is the top coat Dark Grey (lighter than the primer) with Domino flakes (these are sprinkled on as each section is painted. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Floor is done. Quite shiny. Tomorrow we will seal it with clear top coat. It probably will be slippery, however, we will not be adding any grip (comes with it) so it is easier to sweep and keep clean. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Close-up (looks blue in photo but it is grey in reality. You can put as much or as little fleck as you like. All up took a couple of hours. Bought shelving from Bunnings too. Heavy duty system 'Rack-it'. Looking forward to piling stuff in them shelves!!! Coral build- Modified Bronte 42 - We're in!!! https://forum.homeone.com.au/viewtopic.php?f=31&t=82234&p=1513775&hilit=coral+modified+bronte#p1513775 Ask the council if there is a chance of getting build over easement exemption. Sometimes easements are unused and 24cm is not all that much. Good luck. And yes any builder… 2 13771 In Qld it is a requirement that a builder must have a cost breakdown, for building a home to the same specification, with the same inclusions and the same finish. So ask… 1 4337 Ask for references and speak to them. If they are defensive or try to avoid the request, walk. 1 74701 |
