Browse Forums Building A New House 1 Feb 07, 2016 6:56 pm Hi Guys, I am an asian migrant who is interested in building a house in Perth. I'd like to know if there are any home builders building a house using steel frame. I can see that steel frames are quite common in eastern states, but I haven't heard about it in Perth. Please share any idea. Thank you Hi I am wanting some opinions about the build of a steel shed I am going to get one about 4.5 x 2.5 m steel shed and the height will be about 2.3-2.4m high The one I am… 0 14442 You’re on the right track, wire brush in a grinder then a zinc rich epoxy primer then a top coat of some sort, like a waterproofing membrane. Raising the concrete would… 1 7030 Hi, We have a single story MacDonald Jones house, on a waffle pod slab with steel frame. Are we able to build a second story extension? Other info is we are 900mm from… 0 8463 |
