Browse Forums Building A New House 1 Feb 03, 2016 10:56 pm Does anyone know how much grout is the started for Retified polished poecilien tiles? Looking at QBCC standards and tolerances it says. • Finished grout is defective if it is not uniform in colour and is not smooth, without voids, pinholes or low spots and finished to the cushion on cushion edged tiles and flush with square edge tiles, except for tooling in accordance with AS 3958.1 - Ceramic tiles – Guide to the installation of ceramic tiles. We a we so close to PCI I noticed that after they removed the protective flooring. Nearly all of the floor grouting isn't flush. With some areas being flush and others having areas where it is 1-1.5mm deep from the top of the tile. I'm not sure if I'm being fussy or not, as we paid a lot extra to have thin grout lines to get a mirrored finish. Does anyone have picture of how their grout is? Re: Aus standards for grouting Retified tiles? 3Feb 04, 2016 1:37 pm ' and flush with square edge tiles' Guess you have a case! Thanks, I'll check ours next week. Re: Aus standards for grouting Retified tiles? 4Feb 19, 2016 12:34 pm Flush grout is a nightmare for home owners in trying to keep grout clean. You will find the grout that is not flush will stay cleaner longer. All tilers are required to make sure grout is recessed just below the tile which they call tooling. I believe this is correct. From the picture you can see the power was put in last so the electrician knew where the water was. Really it's a common sense issue more… 4 5148 Building Standards; Getting It Right! Don't think they are designed for double brick. WA has a particular way of building and unfortunately that's the way a large amount of sills are finished. 3 6996 2 8621 |
