Oh, come on now...
Page 2 of 4
If there is any variation on either side, it should be on the plans as such.
[img][img]http://i264.photobucket.com/albums/ii191/vonblanks/beach100308037.jpg[/img]
If you have another look at the plan you will see the window is slightly to the right on the plan….not in the centre.
Not in the centre outside………………BUT in the centre of the room inside!!!!!
Sorry, I must be dumb, how can it not be both seeing as it's the only window in that wall, it has to be centre.....and the centreline chain line indicates it is as well....that the long dash-small dash-long dash line. The external dimensions is room dimension + 2 x stud + 2 x cavity + 2 x brick width...unless the quoins are non-symmetrical.
[/img]
[img][img]http://i264.photobucket.com/albums/ii191/vonblanks/house001.jpg[/img][/img]
Take notice of where the hallway wall (internal) picks up from the external walls……
You will see the external wall protrudes slightly more to the left. (Front door)
Then internally, the hall way cuts off the internal walls…….thus making the lounge room wall smaller!
To me.....its very obvious.
Internal dimension = 2650 mm
Difference = 480 mm (2 x 240 mm = standard allowance for external wall)
Centreline marks shows window being in centre of room....
Elevation says it should be in the middle....
Sorry, I'm still dumb....
At the risk of sounding incredibly stupid, I have no idea what you are talking about. I just look at the pretty pictures and they look centre and my house does not...
Michelle's comments are about the lounge room wall, and the front door being on the same wall as that. ( I think?)
Or have I misunderstood the whole thing ??
Im fine with the lounge room window, its the study window that bugging me.
Take another look at the plan…………….now take into consideration the brick wall to the right of the front door, externally.
Now take another look at the same wall on the internals…….the hallway cuts the wall space short…..thus making the window centre internally…….not externally!!!!
Its so obvious!!!!
The study window is what I've been banging on about.....I'm sure that's the problem one.
OMG………..I wondered why everyone couldn’t see it!!!!!!
I’ve been looking at the lounge wall!!!!!
You are right the living room window is not in the center (from the outside), but because the brick walls either side of it are wider from the out side it is not noticeable.
However the study window is where its more noticable, this is the window I believe adlse has a problem with
Lets try again…..
Lets try again…..
NO!.....I like arguing with you.....
Quoins should not make any difference to this.
Now......wasn’t that easy!!!!!
9
Well thats a relief! The whole family is sick of waiting.
16/01/2024
13
This is one of the reasons I decided to go overseas for my double glazed windows. As the builder indicated, he's worked on many upmarket builds, these were the most well…
3/02/2024
2
get an electrician to check and repair before you kill yourself
