Browse Forums Building A New House 1 Dec 07, 2015 10:45 am Hey guys, I'm wondering if anyone has gone down this path and can tell me who you may have used or what material you went with research tells me it can be made from frames and blueboard or from this new lightweight foam. Is there any company in SYD who can premake them according to my specs? ANy help appreciated...Thanks AFAIK, flashing is a minimum standard. Out of curiosity is your window glass stamped with AS requirements in any of the corners of each pane? Im almost certan if theyre… 2 6277 Update from me! Couldn't find the trimmer - not sure if there isn't one simply because the eave is so narrow. Went ahead with the spring toggles and it all worked out… 7 5866 The two 15mm holes are obviously not compliant. The Dept of Fair Trading would love to see this one! Do the gutters pool water after it stops raining? Although it's… 4 7847 |
