Do you reckon 1140mm between the two bench is enough? I was thinking of reducing the bench another 50mm to make the bench less closer to the window, reduce the drawer depth and also it will make the distance 1190mm.
What do you think?
Hi - thanks for your reply. Yes I think 'Ill go for whitish with very speckly bits rather than pure white something like this. PS was actually 2008 I built the…
Old Home Restoration / Renovation
To reduce noise transfer without compromising the aesthetic of your exposed I beams, consider filling the 100mm gap between the I beams and the floor above with dense,…
