Browse Forums Building A New House 1 Nov 19, 2015 2:14 pm I have a issue with my kitchen ceiling. the height of my ceilings are 2700 in my house which is good. In our tender it has a drop of 150mm in the kitchen, but we had our walk through with the builder and we pointed out there was no dropped ceilings. So long story short my options are. 1. leave the ceilings as is and the building will cover the cost to extend the height of my cupboards, bulkhead at 300mm 2. drop the ceiling and leave the height of my cupboards at 2200mm which will give me a 350 bulk head. 3. drop the ceiling and from 2700mm to 2550mm raise my cuboards to 2400mm and have a bulkhead of 150mm. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Kitchen CeiIing Issues 3Nov 19, 2015 2:35 pm The normal reason for dropping ceilings over kitchens is to mark out the region it occupies, but in your case it looks like you've got a U-shaped kitchen, with walls on 3 sides - so I don't know that it achieves so much in that instance, and maybe just makes it a room with a lower ceiling. So based on that, my personal approach would probably be to just raise the tops of the cupboards up to 2400 or 2500 and leave the ceiling as it is. Re: Kitchen CeiIing Issues 6Nov 19, 2015 7:25 pm Yep Go higher cupboards at builders cost. Although the usable space will be high the less used items can live there. Re: Kitchen CeiIing Issues 7Nov 19, 2015 10:42 pm Definitely go the higher ceilings - I have mine right to the ceiling - great storage and it looks wonderful !! My idea!!! Ultimate Homes PERTH '13 Dec Council App '14 Jun Slab '15 Jun Lockup Dec PCI '16 Jan Feb PCI 9 wks ago - still NOT in viewtopic.php?f=31&t=80759 I am looking at building a house. Has anyone used Construkt Homes (based in Adelaide)? Does anyone have experience with this builder? 0 6450 12 5320 Industry type domestic contracts are prepared by industry bodies for the benefit of the builders. This means that if you are the owner watch out. One of the points is… 0 3225 |
