Browse Forums Building A New House Re: Building in Perth - 101 Residential - first ever build 3Nov 06, 2015 2:55 pm You have 1 massive nice house there. And nice pics! I was thinking of doing the stallion stairs too for my build. Alternatively after handover, as I was skeptical that my builder would allows another tradie to do them during construction. Does your builder allows you to do that? Or did you get your builder to supply the stallion stairs? The name's Bond, Color Bond My Ben Trager build thread: "Coming Soon.." Re: Building in Perth - 101 Residential - first ever build 4Nov 06, 2015 3:55 pm Colourbond I'm pretty sure BTH do allow you to do your own stairs however they recommend against it as the credit you get back is minimal and it will be quite costly to do your own. Sounds like you've had a good experience with 101 ![]() Our build thread: https://forum.homeone.com.au/viewtopic.php?f=31&t=70984 Re: Building in Perth - 101 Residential - first ever build 5Nov 06, 2015 4:33 pm ![]() Colourbond I'm pretty sure BTH do allow you to do your own stairs however they recommend against it as the credit you get back is minimal and it will be quite costly to do your own. You maybe right archetto as I haven't had any reply when I asked BTH on this. The quote I got from them for stairs upgrade is $20k with a full frame glass balustrade. I am planning to do spine. I don't have a complete quote yet to compare if its cheaper to use builder to do the stairs upgrade or demolish the standard MDF stairs and install the spine one after handover. The name's Bond, Color Bond My Ben Trager build thread: "Coming Soon.." Re: Building in Perth - 101 Residential - first ever build 6Nov 06, 2015 4:43 pm Thanks colorbond - yeah 101 were pretty good with letting me get an external company come in and do the stairs - I think they do deal with Stallion for some of their products from time to time anyway, so I think that made it easier. it was a very easy process. archetto is correct in saying that the builder gives you minimal credit for the stairs - but Stallion were pretty well priced to be honest, so the difference in what we paid was ok.. it was worth it for me to be 100% happy with the finished product because I just prefer the look of the timber stairs. I think from memory the credit I got for the stairs and balustrade was just over 4k which isn't too bad. So far our experience hasn't been too bad with 101 - a few small hiccups along the way which is always to be expected I suppose. They have told us we might have our PCI just before Christmas so I'm guessing early Jan we will hopefully get our keys if everything is ok. And just to add a little bit of extra stress to the mix, I am actually pregnant with twins due in Feb, so will be cutting it a bit fine if we aren't in by Jan..!! ![]() Re: Building in Perth - 101 Residential - first ever build 7Nov 06, 2015 6:42 pm Awww.. that is so sweet and congratulations! So there are double celebrations to look forward to in the upcoming years. Don't stress too much on the build I'm sure it'll turn out to be awesome. The name's Bond, Color Bond My Ben Trager build thread: "Coming Soon.." Re: Building in Perth - 101 Residential - first ever build 8Nov 25, 2015 12:02 pm So after not having any updates from 101 for a while hubby and i went over to the house to have a look if there had been ANY progress at all.. and to our surprise there has been a bit of work done. All the lights are in, tiling is done although they have stuffed up or kitchen splashback.. I chose subway tiles at pre start and put the note in our specifications for the tiles to be laid in a 'brickwork' pattern like most subway tiles, but they have just laid them in straight lines. Pretty dissapointing but i emailed 101 and they said they will fix it. The kitchen is almost finished by the looks of it.. they are just waiting for the cupboard doors to be delivered (because we chose ones that werent in our builders range) hopefully we will be able to go back when someone is there so we can go in and take a few pics. If the eaves are fixed first, the eaves line is about 250 mm below the top plate of wall frame. If the cladding ie hebel stops just under the eave line, then that means… 2 54986 granny can live in the garage. just give her a few extra blankets rofl 8 34422 You can also consider longer/wider footings for your deck, so you don't even bother with soil capacity calculations. 9 5514 |
