Browse Forums Building A New House 1 Oct 29, 2015 8:58 pm Hai, Just recently came to know that the first floor windows can be opened up to only 125 mm as they have a restrictor on them. I do understand and applaud the reason behind this. Safety of children. My question would be if I wanted to install the safety flyscreens does anyone have an idea approximately how much it would cost to do it after handover by the builder?Would it be worth it as I am guessing again it would be fully meshed and not letting much air in? Thanks. Re: Windows in the first floor can be opened only upto 125mm 2Oct 29, 2015 9:49 pm bbg27 Hai, Just recently came to know that the first floor windows can be opened up to only 125 mm as they have a restrictor on them. I do understand and applaud the reason behind this. Safety of children. My question would be if I wanted to install the safety flyscreens does anyone have an idea approximately how much it would cost to do it after handover by the builder?Would it be worth it as I am guessing again it would be fully meshed and not letting much air in? Thanks. You could perhaps enquire about securemesh or crimsafe. These options wont pop open under the pressure of a child. Re: Windows in the first floor can be opened only upto 125mm 3Oct 29, 2015 9:51 pm Also you depending on the size of the window you could be paying anywhere from $400-$600 a window Thank you. Do I use timber floorboards for stairs or do people use timber treads? Or is both the same? 6 7303 CDC Housing Code 3 When to apply Floor Area external face of wall vs Gross Floor Area internal face of wall. Reading thru CDC Housing Code 3, lets take a lot 915sqm.… 0 16565 isn't a garage level with the rest of the house a given? pretty sure they 'came around' long time ago. if you have a flat block, the garage is usually level with the rest… 1 17528 |
