Browse Forums Building A New House 1 Sep 28, 2015 11:35 am Our block of land (2.5 acres) we are buying has no telecommunication lines. It is in an area that has NBN. Can anyone give me a rough cost if they had to put in a phone line from scratch? There is a house next door and homes across the road that would obviously be connected with landlines. Just wondering what to expect in costs! Re: Phone line/NBN connections 2Sep 28, 2015 12:02 pm Houseandhorse Our block of land (2.5 acres) we are buying has no telecommunication lines. It is in an area that has NBN. Can anyone give me a rough cost if they had to put in a phone line from scratch? There is a house next door and homes across the road that would obviously be connected with landlines. Just wondering what to expect in costs! I'm not too sure what you mean by "telephone line from scratch", do you mean the old twisted pair wire? If this is the case then unless you are in an estate already services with POTS (which your statement about NBN seems to indicate you are not) then the basic answer is - you can't. The telephone service is done differently, with a voice service being offered across your NBN NTD (the device NBN put on the wall), from this there are two voice lines and four data lines that can be connected to various service providers. Many telecommunications companies that offer NBN will sell you a voice package that is used pretty much the same as a normal telephone service but delivered over your nbn fibre. Re: Phone line/NBN connections 3Sep 28, 2015 1:22 pm Are you sure it's NBN over fibre, rather than NBN over fixed wireless? Re: Phone line/NBN connections 4Sep 28, 2015 1:38 pm QuarumNibblet Houseandhorse Our block of land (2.5 acres) we are buying has no telecommunication lines. It is in an area that has NBN. Can anyone give me a rough cost if they had to put in a phone line from scratch? There is a house next door and homes across the road that would obviously be connected with landlines. Just wondering what to expect in costs! I'm not too sure what you mean by "telephone line from scratch", do you mean the old twisted pair wire? If this is the case then unless you are in an estate already services with POTS (which your statement about NBN seems to indicate you are not) then the basic answer is - you can't. Sorry, this is all new to me! Basically I mean we have a paddock with nothing there apart from water, gas, electricity. The nbn website when I search my address says 'service available, fixed wireless'. http://www.nbnco.com.au/connect-home-or ... dress.html Re: Phone line/NBN connections 5Sep 28, 2015 1:56 pm Being wireless, it requires no cabling, so the install would be a similar price to in suburban areas, and may even be free if going on a contract. You'll have to work out if you want a traditional phone as well though, as that would require a cable for the phone line. Otherwise, you can get VoIP (voice over IP), where the phone connects through your wireless data connection. Building Standards; Getting It Right! It's all good. You can get both wye piece and the coupling with or without thread. The cost difference is negligible and means the plumber only has to carry the single… 1 4916 4 10821 Hi everyone, Looking for some advise. We are about to build an above ground pool in our backyard. There is a private sewer line running under the pool at 1.6m… 0 11757 |
