Browse Forums Building A New House 1 Sep 20, 2015 9:57 am Re: Site works - Can someone please explain? 3Sep 20, 2015 7:40 pm Site works is generally cut/fill and sand pad. Basically the bas works before you get a slab. Most builders will itemise things like sand pad, cut and fill, hard digging, stormwater, concrete pump. All of these costs will be on top of the base price they quote you for the house. It is unfortunate, but generally site costs i.e. sand pad and cut and fill will always be a provisional sum. This is just in case they find rock or something else unexpected. For 60K I am assuming you are on am M class site? Re: Site works - Can someone please explain? 4Sep 20, 2015 9:12 pm We are on S class site I think they were giving us worst case scenario. Re: Site works - Can someone please explain? 6Sep 21, 2015 12:20 am I think they quoted on c6 but a site survey hasn't been done, so they were over estimating. Re: Site works - Can someone please explain? 7Sep 21, 2015 9:08 am Hi Teresa22 Site works is a loose title, Quite often what you think is included may not be, eg step downs & Retaining walls, etc,etc These cost components (PS) can also vary once the engineering details are done. Did they advise you/ or give you a copy of the engineering details for S-Type footings. My steps for optimizing the design while minimizing the site costs. 1. Contour survey 2. Site / soil classification report ( Done by an engineer NOT BY A NEW HOME SALES REP) 3. Adjust the floor plan to suit above 4. Have alternative solutions explained/costed/presented to you.. you need to make costly informed decisions early/up front on what's best for you (Short and long term) BTW C1,C2...? are not S class (worse case) footings..I suggest you check the codes. Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Site works - Can someone please explain? 8Sep 21, 2015 10:39 am Thank you for the info.. Redink have quoted the following provisional: Earthworks – Subject to site location, ground levels and access (flat, sandy, level site) $2,450.00 Hard Digging (services only) – Subject to engineers site report $1,000.00 Footing & Slab Detail – D10 Standard – Subject to engineers site report allowed for C6 $16,566.00 But then they also say we are better off getting the rest of the siteworks done externally because chances are they would use the same people we end up using, but then they mark up the price (at least they are honest about that). So I am guessing the sandpad is seperate to the above, as well as the scraping back of the land to level it? Re: Site works - Can someone please explain? 9Sep 21, 2015 10:56 am Teresa22 But then they also say we are better off getting the rest of the siteworks done externally because chances are they would use the same people we end up using, but then they mark up the price (at least they are honest about that). Its always easy to say to the client do it yourself and save? 1. Banks prefer all site works to be completed by the Builder under contract. ie warranties etc 2. That's a worry the Salesman is saying that... 3. If you cant afford it then take it out, doesn't hold for site works, your site works are paramount 4. There is a big difference between $20K and $60K inclusions please do your homework upfront and find out Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Thanks. I wish there was a youtube video explaining this concept. 10 27139 MBA and HIA both have sub contract agreements, check them out 2 7300 I want to build a bigger driveway (without a nature strip) than has been approved under my CDC. I’ve also had a DA approved to build a deck. It looks like I can do this… 0 4783 |
