Browse Forums Building A New House 1 Sep 08, 2015 4:47 pm We have just purchased 360 Square Meter Block in Schofield. Wondering should we go for Single Story house or Double story? Only 1 Kid around 7 Year old so stairs not the problem. Building cost is 20% higher. Which one will give us better return in future? Thanks, Tech 123 Re: 370 Sq Meter Block -Single Story or Double Story House 3Sep 08, 2015 10:31 pm Tech123 We have just purchased 360 Square Meter Block in Schofield. Wondering should we go for Single Story house or Double story? Only 1 Kid around 7 Year old so stairs not the problem. Building cost is 20% higher. Which one will give us better return in future? Thanks, Tech 123 depends on your needs, u get a bigger backyard if u build a double, but some people like single storey with no steps/stairs.. Re: 370 Sq Meter Block -Single Story or Double Story House 4Sep 09, 2015 1:20 pm Hello jai.m & Barnacles279. Thank you for your advise. WE are very small family so we do not need bigger house. Even if we build double story ,it only adds 2 meter backyard. I do not think it is significant to build double story. Regards, Tech 123 Re: 370 Sq Meter Block -Single Story or Double Story House 5Sep 09, 2015 1:27 pm Imho, a double storey always looks more "grand" and would have a better resale value since it also cost more to build. If you can afford it then go double. It is always better to have more space. You don't have to use all the rooms if you don't need to but if you need an extra room, you can't just add it as easily later. Re: 370 Sq Meter Block -Single Story or Double Story House 8Sep 16, 2015 9:44 am $1000 per square metre isn't all that bad. You need to consider your own needs initially, then future resale value in your specific area. You may find most houses are single storey, and having one of the few double storey houses in the area might be a big selling feature and increase your return by a lot more than the initial build cost. Ask real estate agents in the area what they think of the possible increased value of a double versus single storey house. 2 metres of extra backyard space could make a big difference to a future buyer. Ultimately it is your choice alone. Owner Building at Jimboomba Woods in Logan City Qld. Blog : http://bandlnewhomebuild.blogspot.com H1 thread : viewtopic.php?f=38&t=68283 . Re: 370 Sq Meter Block -Single Story or Double Story House 9Sep 16, 2015 9:49 am mwccl Imho, a double storey always looks more "grand" and would have a better resale value since it also cost more to build. If you can afford it then go double. It is always better to have more space. You don't have to use all the rooms if you don't need to but if you need an extra room, you can't just add it as easily later. I'd be careful of this approach. At the end of the day often a house is only worth what someone else is willing to pay (in certain markets). And it also depends on the other houses around and not wanting to over capitalize. I'd also consider aspects such as would you have a view if you went up, are neighboring houses one or two stories (I.e will yours look odd if it's two store u and all around is one?) etc. clever designs for one storey may achieve better functionality etc than a two storey at less cost. Re: 370 Sq Meter Block -Single Story or Double Story House 10Sep 29, 2015 9:37 am Thank you for all your suggestion. I have decided to go for single story house just because of convenience of having all the bedroom on ground floor. Appreciate. Thanks, Tech123 Re: 370 Sq Meter Block -Single Story or Double Story House 11Sep 29, 2015 2:58 pm Have you decided on a design? I know a LOT of builders and know which ones have the best layouts and prices. Re: 370 Sq Meter Block -Single Story or Double Story House 12Sep 29, 2015 2:59 pm Give me a shout if you want help! We bought land in Tallawong Schofields NSW size 30m X 12.5m and planning to get double story house build around 350 sqm. We are thinking about having premium inclusions… 0 4098 Hi, We have a single story MacDonald Jones house, on a waffle pod slab with steel frame. Are we able to build a second story extension? Other info is we are 900mm from… 0 8505 |
