Browse Forums Building A New House Re: Need some advice for retaining wall cost. 2Aug 23, 2015 10:41 am Hi Himanz Unfortunately you haven't provided enough information for even a rough cost? Additional Information that helps 1. Your drawings are inadequate and lack detail such as there are no FFLs, lengths, elevations? etc 2. What are the engineering requirements, details,class footings, soils conditions, Cut & Fill, are piles required for easement? etc 3. Is that face brickwork or rendered, 1.50m averg. height, cavity fill? etc Eg. Class A on sand (Free draining), Cavity fill 300mm 110 FB/100 Conc fill/90 Maxi, 600mm strip footings (no piles), 1.50m high Starter bars, N12 Bars & ties $500-$750 m2 (Measured on Elevation) Details Here https://plus.google.com/u/1/communities ... 2205285216 Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Versaloc is a mortarless besser block system that still needs a properly engineered footing. If you just do a 400x200 footing it will fail in time. At 17m long you need it… 1 17877 Thank you so much for the effort. We will use it to talk with builder. We also had idea of building duplex instead and seeking suggest ions. viewtopic.php?f=31&t=106744 11 13843 Hi All, I engaged a tradie to install concrete retaining wall 600-800mm high over 32 meters in Victoria. Sleepers are 200*75*2000 mm installed over 17 steel posts. I… 0 6917 |
