Browse Forums Building A New House Re: Knock down rebuild site cost 2Aug 18, 2015 6:06 pm What is your soil type? Are you building on slab or bearers & joists? Highly variable, you may have tonnes of rock that needs to be removed, or soil that is mainly clay. There may be drainage requirements etc. Re: Knock down rebuild site cost 5Aug 18, 2015 7:20 pm PVBuild What is your soil type? Are you building on slab or bearers & joists? Highly variable, you may have tonnes of rock that needs to be removed, or soil that is mainly clay. There may be drainage requirements etc. Have not done soil test, no rocks but clay. Building on slab. Re: Knock down rebuild site cost 6Aug 18, 2015 8:11 pm Our site Is H2-D reactive Clay with P classification for fill, trees and KDR, and we're building a house of around 300m2. The site preparation plus cost of footings above standard is about $25k, plus nearly another $5k for spoil removal. This includes footing beams 900mm deep and 300mm wide. The budget builders were talking more around $40k or more for this though, as their "included" footings were less. So if it's reactive clay, $40k isn't so uncommon, but if you have a more stable soil classification you wouldn't expect to be spending that much. Re: Knock down rebuild site cost 7Aug 18, 2015 8:22 pm Our block is 1200sqm our single story house is about 34 sqs - our KDR site costs are $44k We are on h2 P class waffle slab. We are building on clay, no rock. Includes 2 x retaining walls, deepened edge beams. 56 piers in depths varying from1.2 meters deeps to 2.7 meters deep at the rear due to existing trees (council would not let us remove those) Lots of variants but 40k is pretty much spot on. Our fall from left to right is similar to yours Re: Knock down rebuild site cost 8Aug 20, 2015 6:44 pm Am I reading this right... allow $40k to "prepare" the site to build the new home?? Im new to this KDR game and about to go learn about project homes. I would have guessed demolition costs max $10k-15k?? Why is it $40k?? our land is 470sqm.. house on it atm is single storey but double brick. What would that cost be around? Re: Knock down rebuild site cost 9Aug 20, 2015 8:39 pm Demolition should be around $10k, and then less than $5k for preparing the platform. The rest of the money is in the extra footings above "builder standard". For KDR this tends to be higher than greenfields, but the $40k figures are also on account reactive soils. Re: Knock down rebuild site cost 10Aug 20, 2015 9:10 pm We've been quoted $17k for demo as we have asbestos. The unknown site costs are what terrifies me about the kdr process... is it right to suggest you can't be certain of costs until your old house is gone? Re: Knock down rebuild site cost 11Aug 20, 2015 9:29 pm $17k sounds high, at least by Adelaide standards. Ours was just about half that for a 3br house plus large shed lined inside out with asbestos, plus a few large trees. Having the house gone does not affect the site costs. The only real unknown is the footings, and the only thing needed for that is the soil test. They can do that while the house is still there. I think we had our final costs before the house was demolished. Re: Knock down rebuild site cost 12Aug 20, 2015 9:45 pm I'm in Melb. $6k was asbestos alone (garage, side fence, eaves, laundry). Do you mind me asking how you approached your financing oneJohn? Did you have full approval before knocking your place over? I've been told more extensive soil tests are required after demo. Seems a catch 22 that you may not have final costs until demo is done? Re: Knock down rebuild site cost 13Aug 20, 2015 10:18 pm We had quotes like that for demolition too, but it paid to shop around. Disposal is probably more expensive there though. We had plenty of margin in our costs, so finance wasn't an issue for us. But the soil tests were done before demolition, and we did have our final footings costs before demolition. As long as they can get around the house to get some soil samples, they shouldn't need demolition before final costs. We've had the offer of a short term tenant whilst waiting for CDC/DA home approval and demolition for our knock down rebuild. It would achieve a pretty low rent as it's… 0 13987 Hi I live in a 100yr old semi and my neighbour added an additional floor last yr and our architect has advised that we can knock down our semi and build a free-standing… 0 37930 We were lucky in that our old house was so small (86 square metres) compared to the new house, they were able to take enough readings around the old backyard house before… 8 38012 |
