Browse Forums Building A New House Re: Roof Frame question with pics 2Nov 02, 2006 8:02 am Metal battens (or timber) will be fixed to & at right angles to the top chord of the roof trusses at 330mm centres. Peter Clarkson - AusDesign Australia www.ausdesign.com.au This information is intended to provide general information only. It does not purport to be a comprehensive advice. Re: Roof Frame question with pics 4Nov 02, 2006 10:52 am more often than not the tilers. Peter Clarkson - AusDesign Australia www.ausdesign.com.au This information is intended to provide general information only. It does not purport to be a comprehensive advice. This certainly doesn't look good. I would be engaging with an independent inspector to have a look at this. As for the unscheduled site visits, most builders are quite… 1 3503 ![]() 8 14278 ![]() Building Standards; Getting It Right! not sure what you mean, can you post photos, the frame cannot ‘have’ a current, it can be at 240v which is life threatening and should have tripped the circuit.… 1 4108 |
