Browse Forums Building A New House Re: Small (250 mm) eaves, is that too small 21Jul 14, 2008 11:34 am We are aware of the Queensland Development Code, just to give you some back ground info of our proposal.
For the queensland code, its set back is based on MOP not to the wall, so for our block 12.5m, we can have only up to 1.4m set back (includ eaves), but we have a 1.6m set back which mean by the time you add the eave (450mm), our setback becomes only 1.15m. This is the reason we think Council might make us cut our eaves from 450mm to 250mm. Also because we are a standard lot (NOT a small lot), therefore the 1.5m set back to the wall (with 900mm for eaves) for the Redland Small Lot code doesn't apply. But its quite interesting that the Small Lot code actually allow you to have less set back but then consider for 10m frontage block, you can't have a wide house. let me know your thought on this,. Also we are consider some type of shading on the west side. Thanks for the link! And in the end, it's not the years in your life that count. It's the life in your years. Re: Small (250 mm) eaves, is that too small 22Jul 14, 2008 8:47 pm Chloe how wide and deep is your block? What is the site area? From your earlier description it looked like it trigger the Small Lot Code under the RPS 2007.
As stated earlier, the QDC triggers outer most projection, so if you are on a standard lot your building certifier will need to apply for a variation under the Building Act. Re: Small (250 mm) eaves, is that too small 23Jul 14, 2008 10:11 pm The block is about 12.5m wide, 45.278m depth. Its 558m2 size of block which is larger than 500m2. We are a standard lot with a narrow frontage. We will meet the council people later this week and will let you know their feedback. And in the end, it's not the years in your life that count. It's the life in your years. Re: Small (250 mm) eaves, is that too small 24Jul 15, 2008 8:05 pm Chloe I agree with you. From what you have described it is not a Small Lot under the Redlands Planning Scheme.
"Small Lot House: Means the use of premises for a dwelling unit on a lot with an area less than 500m2." What a s&%t definition! It's badly written definitions like this that annoy planners to no ends, let alone the general public. I wholeheartedly agree with you Chloe, it's not a small lot under the Planning Scheme and standard Queensland Development Code Part 11 setbacks apply. My advise is to talk with Council, as your plan was already. Give them your plans, get written advise confirming they are okay with designing the house with smaller setbacks, get your building certifier to lodge a variation under the Building Act 1970 and use the previous correspondence as supporting information. Don't cheapen out of the eaves, do a siting variation. Here is a link to a summary of the Queensland Development Code provisions of the Planning Scheme. http://www.redland.qld.gov.au/SiteColle ... g%20v5.pdf Not sure if that works? I was told the issue is the headspace clearance requirement on step 4. My builder is proposing shifting the beam 310mm towards the kitchen...I'm… 2 2658 Update from me! Couldn't find the trimmer - not sure if there isn't one simply because the eave is so narrow. Went ahead with the spring toggles and it all worked out… 7 5879 The two 15mm holes are obviously not compliant. The Dept of Fair Trading would love to see this one! Do the gutters pool water after it stops raining? Although it's… 4 7872 |
