Browse Forums Building A New House 1 Aug 04, 2015 1:16 pm Hi I have recently bought a battle axe block. The build area is 18m wide and 22m long. I am on the lookout for floor plans that fit a battle axe block. Please share if you have any. Ideally, I would like a 4x2 with activity room. Re: Building on Rear Block or Battle Axe Block - Floor Plans 2Aug 04, 2015 2:39 pm We are going with the Ellison by Ausbuild on our battle axe block. Re: Building on Rear Block or Battle Axe Block - Floor Plans 3Aug 06, 2015 4:03 pm Orientation is very important. In most Aussie climates you want to let the sun in in winter & keep it out in summer. This is best achieved by having a high proportion of your glazing facing north (& locating your living areas here), & minimising W & E facing windows. Hopefully you can find a floor plan that does this, & matched your block. Good luck. Hi All, see above image. The required setback from the rear boundary in my case is 5m, as you can see the shape of the site and location of the boundary is slightly… 0 8461 CDC Housing Code 3 When to apply Floor Area external face of wall vs Gross Floor Area internal face of wall. Reading thru CDC Housing Code 3, lets take a lot 915sqm.… 0 16563 |
