Browse Forums Building A New House Re: What to do with left over ceramic floor tiles? 2Jul 27, 2015 3:41 pm I'm planning on keeping them all. What if you have a flood or fire and you have a big section damaged? If you have a really large amount left over you might want to try to sell them on gumtree or something...But otherwise keep them if you can. Jen (& Dave) Plantation Bronte, Ormeau Ridge, Gold Coast QLD 12/03/2015 - Commencement... 26/08/2015 - Handover! viewtopic.php?f=31&t=76446 To put anything over slate you will need to put self level compound over the entire area as slate various in thickness and is very un even. To install most types of… 1 412 you need a fridgie to answer but I would think you vac the whole system then add gas if you have a leak, unless it is new install with the gas already loaded, in that case… 1 3663 Old Home Restoration / Renovation Hi, just discovered all these junks left behind under the floor. Could any of these be asbestos? Best to leave as it is or clean up? Thank you for your thoughts 0 8070 |
