Browse Forums Building A New House 1 Jul 26, 2015 1:25 am Hi Guys,
Where do you reckon would be best to have the TV mounted on this floor plan The wall parallel to the kitchen bench is around 5 metres (Red line is where the Living rooms stops) The other wall is 4.2 metres and has around 1200mm wide opening to the living room (What is the minimum this opening could be to be large enough without feeling too narrow?) Which one will be the better option for mounting the TV? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Where to have TV mounted on this plan 2Jul 26, 2015 8:54 am Mhmm, well given you have no windows on either wall they are both good options. Really depends on your furniture placement.. I would probably go opposite the kitchen bench, so I could watch TV easily from the kitchen.. I'm a single person with no attention span so watching TV while cooking is all that keeps me from burning the house down. However this would mean you'd probably have the couch facing the TV and creating a blocking line across the bench in the kitchen.. so probably the other wall, which could then be watching from the dining table After looking at it a bit, I reckon the wall opposite the kitchen.. less distraction from people going through the door and everyone can see the TV. Good luck! Re: Where to have TV mounted on this plan 3Jul 26, 2015 10:05 am Just wondering if you're sure your measurements are correct? Looking at your dwg it says the wall you walk in to living room is 5410 and the wall opposite island bench would be 4680. Also is your entry to living definitely 1200 as looks far narrower if you estatimate scale based on the lard dimensions on the plan. Nonetheless, I'd have TVon the wall opposite island bench. Can then be viewed from kitchen and if you have couch to face it, back of couch can form a boundary to create a kind of walkway between island bench and the living area. As for entrance size I think 1200 is plenty wide enough and will help with moving furniture too. Re: Where to have TV mounted on this plan 5Jul 26, 2015 3:19 pm The width of the room is 5410 but the distance from the end of the living room to the opposite wall is 5m. The entrance to the living to was set to 1350 but I will decrease it to around 1100-1200 to increase usable space in the living and meals room. Room on either side are media for the other just the entry hallway. Will upload a bigger plan in a minute. Regarding tv location is it better to have it 5m x 4.2m longer on length side or the other way around? Re: Where to have TV mounted on this plan 9Jul 29, 2015 12:37 pm Media room will have a projector projecting to the ensuite wall Re: Where to have TV mounted on this plan 10Jul 29, 2015 12:38 pm GSP07R i would place it on the media room side and it would be easy to run the wiring. where are you placing the media room tv Is 4 metres enough depth for distance to the tv from the couch? Re: Where to have TV mounted on this plan (UPDATED) 12Jul 29, 2015 2:46 pm I would also put it on the wall opposite the kitchen. Easily viewable from kitchen, lounge and meals. I personally am not keen on your latest idea, the TV seems to be floating in the middle of nowhere. I think it always looks better if the lounge area has two walls at least around it, with the couch/es forming at least one other 'wall'. My blog: tashandpaul.wordpress.com Re: Where to have TV mounted on this plan (UPDATED) 14Jul 29, 2015 6:30 pm Alexxdavid GSP07R i would place it on the media room side and it would be easy to run the wiring. where are you placing the media room tv Is 4 metres enough depth for distance to the tv from the couch? I would have thought 4m was a fine distance from couch to TV Re: Where to have TV mounted on this plan (UPDATED) 15Jul 30, 2015 12:38 am GSP07R agree with tash. will you just be hanging it off the wall or will there be a cut out for it to sit in? It will be a wall mounted TV Hello everyone, I have a question regarding moving a chandelier after it has been mounted. The chandelier in question is quite large, measuring 4 meters… 0 72337 i thought the flipped plan initially but bec i want narrow pathway from entry to dining (dont like bend), also cannot fit the… 7 17278 5 10476 |
