Browse Forums Building A New House 1 Jul 09, 2015 9:41 am hi guys, Lockup stage has just finished. Got a notice from surveyor yesterday, saying the house/floor is higher than the working design(about 300mm higher). Builder says he is handling this. What could be the result? How should I deal with this? Cheers, Re: House built higher than the design 2Jul 09, 2015 10:17 am Can't see how they can "handle it". It's either at the right height or it's not. Whether it's a problem or not is another matter. Re: House built higher than the design 4Jul 09, 2015 11:07 am The fact that there has been 300 mm error is a cause for concern because obviously no one is on top of quality control and there is serious risk there will be other errors. The current error will impact on your landscaping and egress (assuming your home now does not breach planning height restrictions). If you have not already, you should get independent inspector to help you keep an eye on your build and guide you through this issue Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: House built higher than the design 5Jul 09, 2015 11:35 am For this particular issue, the the first thing to work out is how you feel about the level the house is at - whether it will work ok with the driveway and the yard levels. If you're happy at the height it's at, then it's probably not going to be a big issue. If that level creates problems, then you'll need to find if there are landscaping solutions to it that you'll be happy with, and try to get the builder to pay for the works needed for that. Re: House built higher than the design 6Jul 09, 2015 1:28 pm We had this happen, our building inspector advised us in our case it was to our advantage as far as site drainage went. It dod affect us with landscaping as had to bring soil in to make garden a similar level to house. You also m8ght want to consider higher fences if privacy an issue. interesting situation what happened after builder issued final invoice? did you list as defect or not does the building surveyor have any responsibility? ie. issuing… 13 46961 DIY, Home Maintenance & Repair We purchased a 1960s property that is on timber stumps mostly, and a newer section is on concrete stumps. We had a building inspection initially and they reported some… 0 12745 Strong enough for what? For linen, absolutely. To climb on, no. I've got similar shelving in my garage and it holds a decent amount of weight. 900 wide shelves will carry… 1 4193 |
