Browse Forums Building A New House 1 Jul 08, 2015 3:07 pm Hi Just a newbie to this forum we are in the process at looking for a builder in Sydney for a knockdown and rebuild of our current 3bd brick vaneer house. We are looking at also attaching a granny flat to this project. Wanted to know anyones experience with the builders ... looking at Masterton or Rawson Homes but also considering some local builders. Would love some advice as we have no idea about building and what are hidden costs etc from these builders. thanks Re: Knock down and rebuild 2Jul 08, 2015 3:43 pm Hello we are building with masterton our experience is detailed in my blog although we are not doing a KDR there is a lot helpful costing information on there. Good luck https://mandgbuildatmulgoarise.wordpress.com/ Re: Knock down and rebuild 3Jul 08, 2015 4:49 pm We explored an option for a detached building with Rawson during the tender stage and they were quite adamant that unless they were building it, it wouldnt be provided in their drafting plans. You might need to look for flexible project builders that could provide the planning/drafting to give you an approved plan to build the detached dwelling later ( ie. within the next 4 years). If your budget allows though, most project builders will likely do it if they can charge you to build it. Just be aware that any planning shortcuts like a private certifier process will not work if you have a detached dwelling as it will most likely need to follow the traditional DA process. Good luck with your investigations. Knock down and rebuild 4Jul 09, 2015 7:52 am There is a person on the Clarendon home website who is building a detached granny flat which Clarendon is doing for them search for granny flat under the Clarendon feed. We are going private small builder. With our build which has granny flat viewtopic.php?f=31&t=75739&p=1299716#p1299716 We've had the offer of a short term tenant whilst waiting for CDC/DA home approval and demolition for our knock down rebuild. It would achieve a pretty low rent as it's… 0 13750 Hi I live in a 100yr old semi and my neighbour added an additional floor last yr and our architect has advised that we can knock down our semi and build a free-standing… 0 37693 if the original house is in good condition most of what you listed could be added in stages without the need for KDR and costs and disruption of having to live elsewhere… 1 13673 |
