Browse Forums Building A New House Re: Dream Metricon Glendale 38 (Sydney)! 4661Mar 22, 2017 5:49 am Thanks all! Quick Q, should M paint all around the DP? The inside facing the brick is unpainted? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ @Orph Build thread: viewtopic.php?t=78328 Home Furniture: viewtopic.php?t=80551 Technology Hub: viewtopic.php?t=83663 Landscape Design: viewtopic.php?t=80645 Orpheus Building the Metricon Glendale 38|Sydney Re: Dream Metricon Glendale 38 (Sydney)! 4662Mar 22, 2017 6:07 am Based on the other Metricon builds I've seen on this forum (and other builders as well) this looks like it's common practice as they paint the downpipes after fitting them on Re: Dream Metricon Glendale 38 (Sydney)! 4663Mar 22, 2017 6:35 am anonymous- Based on the other Metricon builds I've seen on this forum (and other builders as well) this looks like it's common practice as they paint the downpipes after fitting them on Hmm, that's a bad job.... @Orph Build thread: viewtopic.php?t=78328 Home Furniture: viewtopic.php?t=80551 Technology Hub: viewtopic.php?t=83663 Landscape Design: viewtopic.php?t=80645 Orpheus Building the Metricon Glendale 38|Sydney Re: Dream Metricon Glendale 38 (Sydney)! 4665Mar 22, 2017 6:39 am Orpheus Thanks all! Quick Q, should M paint all around the DP? The inside facing the brick is unpainted? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ @Orph Build thread: viewtopic.php?t=78328 Home Furniture: viewtopic.php?t=80551 Technology Hub: viewtopic.php?t=83663 Landscape Design: viewtopic.php?t=80645 You would think so! I am yet to check. Re: Dream Metricon Glendale 38 (Sydney)! 4666Mar 22, 2017 6:57 am We had the same with our downpipes and the SM added to his list of things to fix for handover ------- Metricon Aria https://ourlittlearia.wordpress.com/ Re: Dream Metricon Glendale 38 (Sydney)! 4667Mar 22, 2017 7:04 am All the best for today. It's been a long road but you've finally made it! C U S T O M. C O R A L. B R O N T E. 43 http://forum.homeone.com.au/viewtopic.php?t=79581 M Y C U S T O M C O R A L B R O N T E 43 ...............Kitchen! 16 Nov 2016 https://forum.homeone.com.au/viewtopic.php?f=31&t=79581 Re: Dream Metricon Glendale 38 (Sydney)! 4668Mar 22, 2017 7:20 am Mine are the same and it is on my list of things to fix. I don't expect three coats but at least one Nev _________________ Blog | ( will start once received tender ) H1 thread | https://forum.homeone.com.au/viewtopic.php?f=31&t=77665 Re: Dream Metricon Glendale 38 (Sydney)! 4669Mar 22, 2017 8:09 am Orpheus Thanks all! Quick Q, should M paint all around the DP? The inside facing the brick is unpainted? Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ @Orph Build thread: viewtopic.php?t=78328 Home Furniture: viewtopic.php?t=80551 Technology Hub: viewtopic.php?t=83663 Landscape Design: viewtopic.php?t=80645 All our money we invest in our homes and they can't make the effort to paint that bit? Can't believe it Re: Dream Metricon Glendale 38 (Sydney)! 4670Mar 22, 2017 1:16 pm Hi All, PCI was good but there were still lots outstanding items and defects: 1. Main concern is a cracked floor tile directly under the balustrade in the balcony. To replace the tile will involved major rework.... 2. Soft close hinges and runners not installed 3. Alarm pad not working due to cabling issues 4. Paint rework and touch ups not completed. Painters were working during our PCI 5. Large windows with flyscreens have a thick centre metal rod so the flyscreen frame doesn't sag or bow. Why can't they design a stronger frame to support the flyscreen? 6. Downpipes not painted all the way around and apparently this is M standard? I need to check the display homes again. Our SM said he will try to get painters do it properly (not holding my breath) 7. Lots of electrical works (light fittings, GPOs, faulty lights 8. Pergola works incomplete 9. Data/comms cables not labelled (WTH) 10. Site needs a major clean Only good news is out SM will see if the painters can change our rendered pillar to surfmist.... Here's hoping all these can be rectified in a couple of weeks for handover plsssssssss . Don't have any more pictures so will have to wait under handover now..... @Orph Build thread: viewtopic.php?t=78328 Home Furniture: viewtopic.php?t=80551 Technology Hub: viewtopic.php?t=83663 Landscape Design: viewtopic.php?t=80645 Orpheus Building the Metricon Glendale 38|Sydney Re: Dream Metricon Glendale 38 (Sydney)! 4671Mar 22, 2017 1:22 pm Orpheus Hi All, PCI was good but there were still lots outstanding items and defects: 1. Main concern is a cracked floor tile directly under the balustrade in the balcony. To replace the tile will involved major rework.... 2. Soft close hinges and runners not installed 3. Alarm pad not working due to cabling issues 4. Paint rework and touch ups not completed. Painters were working during our PCI 5. Large windows with flyscreens have a thick centre metal rod so the flyscreen frame doesn't sag or bow. Why can't they design a stronger frame to support the flyscreen? 6. Downpipes not painted all the way around and apparently this is M standard? I need to check the display homes again. Our SM said he will try to get painters do it properly (not holding my breath) 7. Lots of electrical works (light fittings, GPOs, faulty lights 8. Pergola works incomplete 9. Data/comms cables not labelled (WTH) 10. Site needs a major clean Only good news is out SM will see if the painters can change our rendered pillar to surfmist.... Here's hoping all these can be rectified in a couple of weeks for handover plsssssssss . Don't have any more pictures so will have to wait under handover now..... @Orph Build thread: viewtopic.php?t=78328 Home Furniture: viewtopic.php?t=80551 Technology Hub: viewtopic.php?t=83663 Landscape Design: viewtopic.php?t=80645 Good to know PCI went well.. issue #9 you gonna enjoy fixing it.... Re: Dream Metricon Glendale 38 (Sydney)! 4672Mar 22, 2017 1:32 pm Dw, I'm not handing over payment until they label each cable. @Orph Build thread: viewtopic.php?t=78328 Home Furniture: viewtopic.php?t=80551 Technology Hub: viewtopic.php?t=83663 Landscape Design: viewtopic.php?t=80645 Orpheus Building the Metricon Glendale 38|Sydney Re: Dream Metricon Glendale 38 (Sydney)! 4673Mar 22, 2017 1:52 pm Oh geez Orph doesn't sound like yours went too much better than mine! Hope they can get through things quickly! When will he give you a handover date? Re: Dream Metricon Glendale 38 (Sydney)! 4674Mar 22, 2017 1:57 pm No dates but 1-2 weeks is general rule @Orph Build thread: viewtopic.php?t=78328 Home Furniture: viewtopic.php?t=80551 Technology Hub: viewtopic.php?t=83663 Landscape Design: viewtopic.php?t=80645 Orpheus Building the Metricon Glendale 38|Sydney Re: Dream Metricon Glendale 38 (Sydney)! 4675Mar 22, 2017 3:25 pm Here here about the flyscreens doors!! I haven't ordered any yet as I can't commit to something so ordinary looking. Seems the only doors without the Bar are the metal security screens. Not everyone has kids or pets... Seriously!! C U S T O M. C O R A L. B R O N T E. 43 http://forum.homeone.com.au/viewtopic.php?t=79581 M Y C U S T O M C O R A L B R O N T E 43 ...............Kitchen! 16 Nov 2016 https://forum.homeone.com.au/viewtopic.php?f=31&t=79581 Re: Dream Metricon Glendale 38 (Sydney)! 4676Mar 22, 2017 3:37 pm MrsJM Here here about the flyscreens doors!! I haven't ordered any yet as I can't commit to something so ordinary looking. Seems the only doors without the Bar are the metal security screens. Not everyone has kids or pets... Seriously!! C U S T O M. C O R A L. B R O N T E. 43 http://forum.homeone.com.au/viewtopic.php?t=79581 Thanks JM, The flyscreens for the stacker doors have a horizontal bar which I'm ok with as its a safety issue to prevent ppl from walking into the flyscreen. But there is no need for the bar in the flyscreens for the windows. I will upload some photos of the flyscreens soon. @Orph Build thread: viewtopic.php?t=78328 Home Furniture: viewtopic.php?t=80551 Technology Hub: viewtopic.php?t=83663 Landscape Design: viewtopic.php?t=80645 Orpheus Building the Metricon Glendale 38|Sydney Re: Dream Metricon Glendale 38 (Sydney)! 4677Mar 22, 2017 5:25 pm Photos of flyscreens. You can see the vertical bar in the middle which is hideous... Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ I don't like the horizontal bar on the flyscreen for the stacker doors but don't mind it as its a safety precaution. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ @Orph Build thread: viewtopic.php?t=78328 Home Furniture: viewtopic.php?t=80551 Technology Hub: viewtopic.php?t=83663 Landscape Design: viewtopic.php?t=80645 Orpheus Building the Metricon Glendale 38|Sydney Re: Dream Metricon Glendale 38 (Sydney)! 4678Mar 22, 2017 5:56 pm Orpheus Photos of flyscreens. You can see the vertical bar in the middle which is hideous... Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ I don't like the horizontal bar on the flyscreen for the stacker doors but don't mind it as its a safety precaution. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ @Orph Build thread: viewtopic.php?t=78328 Home Furniture: viewtopic.php?t=80551 Technology Hub: viewtopic.php?t=83663 Landscape Design: viewtopic.php?t=80645 How weird, ours aren't like that. There might be a bar on the sliding door for laundry, not sure. We don't have them on stacker door. On another topic, i love how neat your light switch and fan switch look all close together and pretty. Ours is about 30-40cm apart (above/below) for both alfresco and living, looks ridiculous!!!! Re: Dream Metricon Glendale 38 (Sydney)! 4679Mar 22, 2017 6:41 pm kylz4 Orpheus Photos of flyscreens. You can see the vertical bar in the middle which is hideous... Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ I don't like the horizontal bar on the flyscreen for the stacker doors but don't mind it as its a safety precaution. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ @Orph Build thread: viewtopic.php?t=78328 Home Furniture: viewtopic.php?t=80551 Technology Hub: viewtopic.php?t=83663 Landscape Design: viewtopic.php?t=80645 How weird, ours aren't like that. There might be a bar on the sliding door for laundry, not sure. We don't have them on stacker door. On another topic, i love how neat your light switch and fan switch look all close together and pretty. Ours is about 30-40cm apart (above/below) for both alfresco and living, looks ridiculous!!!! Thanks Kylz. Must be difference in window companies. I'm gonna tell our SM to detach the middle bar off, otherwise I'm not gonna fit them and get a refund. Looks so stupid. Yeah the light switch (one above is for outdoor heaters) was done during installation as an extra so we only gotten the standard switch. Need to replace it with the Saturn range (with blue LED) @Orph Build thread: viewtopic.php?t=78328 Home Furniture: viewtopic.php?t=80551 Technology Hub: viewtopic.php?t=83663 Landscape Design: viewtopic.php?t=80645 Orpheus Building the Metricon Glendale 38|Sydney Re: Dream Metricon Glendale 38 (Sydney)! 4680Mar 22, 2017 8:10 pm Orpheus No dates but 1-2 weeks is general rule @Orph Build thread: viewtopic.php?t=78328 Home Furniture: viewtopic.php?t=80551 Technology Hub: viewtopic.php?t=83663 Landscape Design: viewtopic.php?t=80645 Hopefully sooner Orph that list has decreased and look to be mostly minor jobs (except tiles) what will they do for the tile fix? Done before or afterwards? Hi, First of all, thank you to this community for sharing your thoughts and opinions. We are in early days of our pre-contract stage for Metricon Doulton and we are… 0 11165 Hello All 🙂 We are planning to start our journey of construction our first home. We zeroed down on Metricon and henley homes based on design suitable for our lot and… 0 8586 We don’t live in VIC so want to know the exterior colours of Lumiere display so we can see it at the paint shop. Not building with Metricon so my request went… 0 18198 |
