Browse Forums Building A New House Re: New home Landscaping - Landscape Designer or DIY 10Jul 04, 2015 3:31 pm I spoke with several designers, who were also available to project manage the whole job. Problem is, they wanted $1500-$3500 just for the design, and many would charge more if you wanted to vary it after they'd designed it. But, what if I don't like what they came up with? Too bad. Two different designers even asked for a $100-$200 fee just to look at the site. That's crazy. Thankfully, we found a young up-and-coming landscaper looking to make a break into bigger jobs (ours is going to run close to 100K I think). So, he'll actually work harder and put in more effort than someone established - even if the job takes a little more work from us (in terms of guiding the design). And honestly, the designers I spoke with sounded like used-car salesman - and not enthusiastic about the job at all. I want someone who's excited and wants to do the the best with our guidelines and our budget. Assuming the structure of your cabinetry is good then I would DIY everything as follows: - replace your counter tops entirely, - replace all drawer runners with soft close… 1 4782 No access to subfloor unfortunatly. I drilled a small hole and missed a stump , I plan is to cut a man hole and do a proper inspection 2 2586 a building inspector should be able to tell you about any major problems but we need a floor plan with dimensions to clarify options for extra bedrooms ... sometime an… 1 8718 |
