Browse Forums Building A New House Re: Eaves 2Jun 29, 2015 12:03 pm If what you are asking is if the eaves are included in setbacks, then yes. A setback is measured from the building's outermost projection Dale - Building Newbie Proserpine, QLD Re: Eaves 3Jun 29, 2015 12:11 pm I've found councils to get quite vague about this. If pushed to technicalities, they will say that the setback is the distance to any part of the building at all, including gutters. However, for most applications of setback requirements, they seem happy for the eaves and gutters to be inside the setback region. So to answer the question, generally they can encroach, but it can come down to the detail of the development control plan, and the convention of the council. Re: Eaves 4Jun 29, 2015 12:25 pm That will depend on your local council and how they view it as much as anything else. Ours has a 900mm side setback to the walls but will let your eaves slightly more until you reach the 675mm max limit of any roof projection. http://i1212.photobucket.com/albums/cc455/stewiesno1/BoundaryClearance_zpsdc2a238b.jpg The front setback ( 6.5m ) they will allow a full eaves incursion of 450 - 600mm without any problems. Stewie Re: Eaves 5Jun 30, 2015 3:38 pm Thank you all for replying. I dug through our contract and it specifies that eaves (among other things like pergolas and verandahs) are allowed to encroach into setbacks. Ours will be a 9ft ceiling height. I'm thinking 600mm eaves would be more suitable, but they're going to cost over 3k, so wondering whether to get them or not. I prefer the look with eaves. Re: Eaves 8Jun 30, 2015 6:45 pm JG king for the memphis are 2000 for 450 and 2500 for 600 no eaves on the garage though. To add to that I just looked at our quote 450mm was $40 per meter and 600 $50 per meter. Our Build Thread - JG king Memphis Re: Eaves 11Jul 01, 2015 8:46 am I'm surprised if an eaves element is not included as part of your 5 star rating for houses ( if you are in Victoria ). In NSW , shading of your E, N & W windows and doors is a requirement as part of obtaining a BASIC certificate for DA approval. The shading can be eaves, adjustable awnings, upgraded frame and glass for those windows and doors or overshadowing by trees or neighbouring properties. Stewie Update from me! Couldn't find the trimmer - not sure if there isn't one simply because the eave is so narrow. Went ahead with the spring toggles and it all worked out… 7 5864 The two 15mm holes are obviously not compliant. The Dept of Fair Trading would love to see this one! Do the gutters pool water after it stops raining? Although it's… 4 7845 |
