Please help me with this.
Our main entry door is glazed clear glass - what type of tint should I use to achieve a zero visibility (looking in from outside at night) if our lights are up?
Browse Forums Building A New House Re: Tinting: Zero visibility from the outside at night 3Jun 28, 2015 8:25 am No - seriously - tint will do this. Maybe some sort of partition ? Otherwise it will be too dark in the day time - ie no good light. Re: Tinting: Zero visibility from the outside at night 4Jun 28, 2015 9:18 am Could try one way mirror tint I've seen it used on cars about ten years ago Re: Tinting: Zero visibility from the outside at night 5Jun 28, 2015 11:05 am One way reflective tint only works if the light on the reflective side is brighter than the other side. One way around is to use a reflective tint, and have a fairly bright light outside. The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Tinting: Zero visibility from the outside at night 7Jun 28, 2015 5:27 pm bashworth One way reflective tint only works if the light on the reflective side is brighter than the other side. One way around is to use a reflective tint, and have a fairly bright light outside. Thanks for this info bashworth - I am now thinking of having a bright LED on my porch and a not so bright down light inside. Again this is interesting.... Re: Tinting: Zero visibility from the outside at night 8Jun 28, 2015 5:31 pm goody59 Roller blind on door maybe. I have seen that before. This could an option too. With the one you've seen, was the roller blind attached to the actual door or to the door's header/jamb? Re: Tinting: Zero visibility from the outside at night 9Jun 28, 2015 5:48 pm Skull goody59 Roller blind on door maybe. I have seen that before. This could an option too. With the one you've seen, was the roller blind attached to the actual door or to the door's header/jamb? Attached to door. Re: Tinting: Zero visibility from the outside at night 10Jun 28, 2015 11:54 pm I thought companies who did tinting and the like made some sort of translucent film nowadays for situations like this? I'll be needing a similar solution when my house is done as my doors are clear as well. Bit of googling: http://www.avtechwindowtinting.com.au/w ... /index.php http://www.dmstinting.com.au/window-pri ... Y__MUbJI2I http://www.tintingdirect.com.au/frosted ... films.html Looks like there are plenty of options, plain for decorative Re: Tinting: Zero visibility from the outside at night 11Jun 29, 2015 11:18 pm Jdvee I thought companies who did tinting and the like made some sort of translucent film nowadays for situations like this? I'll be needing a similar solution when my house is done as my doors are clear as well. Bit of googling: http://www.avtechwindowtinting.com.au/w ... /index.php http://www.dmstinting.com.au/window-pri ... Y__MUbJI2I http://www.tintingdirect.com.au/frosted ... films.html Looks like there are plenty of options, plain for decorative http://www.tintingdirect.com.au/window- ... nting.html - this is from your 3rd link and it very useful info - thanks so much Jdvee Re: Tinting: Zero visibility from the outside at night 13Jul 08, 2015 5:20 pm just an update - i went to 3 different tint suppliers/installers today asking what is the best solution for my clear glass main door so that i wont be able to be seen inside from outside at night - all 3 answered frost film. Re: Tinting: Zero visibility from the outside at night 14Jul 08, 2015 7:07 pm Hmmmm me thinks I'm going to have this same problem but I hate the look of frost film! Some of the bubbly type glass you use in bathrooms works a treat. We had new doors installed on an 80s build recently and found a bubble that is really subtle which I've never seen in a bathroom type window, and suited the doors. Once you move about 10cm back from The door on inside you can see anything from the outside except like a pale shadow. Maybe that would suit the style of door you have. Re: Tinting: Zero visibility from the outside at night 15Jul 25, 2015 10:02 am Beazley77 Hmmmm me thinks I'm going to have this same problem but I hate the look of frost film! Some of the bubbly type glass you use in bathrooms works a treat. We had new doors installed on an 80s build recently and found a bubble that is really subtle which I've never seen in a bathroom type window, and suited the doors. Once you move about 10cm back from The door on inside you can see anything from the outside except like a pale shadow. Maybe that would suit the style of door you have. yours is interesting. Grateful if you could elaborate more about frost film - - - -any links please would be greatly appreciated. Thanks a lot. Re: Tinting: Zero visibility from the outside at night 16Jul 25, 2015 2:38 pm We also will have a clear glazed front door (1200mm wide too!). We are planning on putting a screen door on the front of it which will cut down some of the visibility, and it is kinda set back into the porch so not smack bang straight onto the street. I agree with you not wanting frost film, it kinda defeats the point of having a clear glazed door! Our Custom Dale Alcock build in the Village at Wellard https://forum.homeone.com.au/viewtopic.php?f=31&t=78620 Re: Tinting: Zero visibility from the outside at night 17Jul 25, 2015 9:21 pm i got a roll of frost tint for my front door from bunnings. it cost about $7 for the roll and only needs water to stick it to the glass. I didnt want people looking through the glass but still wanted the light to come through. Re: Tinting: Zero visibility from the outside at night 19Oct 08, 2015 6:17 am I've seen a sort of lace/curtain affair. Not sure if its dated or not but can be nice - and private. Allows light in. Perhaps even a design of louvres ? Re: Tinting: Zero visibility from the outside at night 20Oct 08, 2015 7:43 am Hi everyone. There is a beautiful home near us that has a big glass door and it is somehow tinted very very dark/a black/silver. It looks soooooo good! You totally can't see in. We were going to do the same but I feel like I may have to knock on their door to ask! It almost looks like a mirror glaze but not tacky if that makes sense! If I find out what it is, I'll post it on here! Mon You must be new to the internet. You're also the only person anyone here has ever heard of washing their garage wall. I hate to break it to you, there are insects and… 6 4848 I am building in claymore NSW and this is shown in the building envelope plan. … 0 10035 |
