Browse Forums Building A New House 1 Jun 21, 2015 8:35 pm Hi Guys, After a sore 16 months wait we are finally getting there. Unfortunately, I noticed a 60mm difference in the garage pelmet. One end is 60mm larger that the other. We can see it clearly when the garage door is closed it looks awful. I don't Know anything about building standards, I guess that is what I hired a builder for. To ensure it was done right, but it doesn't seems to be the case. I wonder if there is anyone readying the forum that know the technical side and the standard tolerances and could clarify it for me. Please have a look at the image below. I really appreciate any thoughts Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Thanks Re: Dimensions Tolerance - HELP PLEASE 2Jun 21, 2015 9:31 pm Hi The document at this link is a starting point http://www.vba.vic.gov.au/__data/assets ... s-2015.pdf Although I believe that if you can see it looks wrong . . . then it is wrong. The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Dimensions Tolerance - HELP PLEASE 3Jun 21, 2015 9:36 pm Hi bashworth, Thanks for your repply. I am trying to find a WA version of that document. I was looking at it though and I am not sure if this is an external door specification or frame. Anyways none of them seem to accept 60mm difference. Re: Dimensions Tolerance - HELP PLEASE 4Jun 22, 2015 4:09 pm I called the garage door manufacturer and turns out the builder ordered a Taped, pelmet. So to me it indicates they knew there was something wrong. It leaves either the roof line or the garage floor. In any case I don't thing a 60mm is considered standard. Re: Dimensions Tolerance - HELP PLEASE 5Jun 22, 2015 4:37 pm Perhaps if you could try to post the photo again I might be abe to comment further (as I can't see it on your first post) The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Dimensions Tolerance - HELP PLEASE 6Jun 22, 2015 4:41 pm That looks awful! I wouldn't be happy with that at all Our build thread: https://forum.homeone.com.au/viewtopic.php?f=31&t=70984 Re: Dimensions Tolerance - HELP PLEASE 7Jun 22, 2015 5:09 pm Hi Bashworth, Sure here is a link http://postimg.org/image/cyypmocmv. I am not quite sure how to add it. <img src="http://postimg.org/image/cyypmocmv"/> Re: Dimensions Tolerance - HELP PLEASE 8Jun 22, 2015 6:30 pm Certainly doesn't look great. Part of the reason may be to avoid having a down pipe at the left of the picture. The Harder You Try - the Luckier You Get ! Web site http://www.anewhouse.com.au Informative, Amusing, and Opinionated Blog - Over 600 posts on all aspects of building a new house. Re: Dimensions Tolerance - HELP PLEASE 9Jun 22, 2015 6:37 pm Yeh, I am not sure. but 60mm to 80mm is a lot and it looks bad. I will be meeting the supervisor tomorrow, lets see what he says. I am not keen to let this one go, I work hard and I have to do things right at work in order to have a job and get paid. So I won't be happy to give some of my earned money for poor quality job. If I have not choice they will be getting lots of bad posts on Facebook for the rest of the year. I will post an update tomorrow. Cheers i inspect..there is no construction tolerance or building tolerances. Your option to instruct council with your surveyors report as they would have possibly had to obtain… 9 5591 7 2996 Thankyou so much 😀 I've decided on White on white for doors and trims, White on white 50% on ceiling and Mt buller for walls. Fingers crossed it will look OK 😀 2 7143 |
