Browse Forums Building A New House Re: Building with Metricon 4261Jan 11, 2017 6:16 pm Would the skirting negatively impact the fridge space that much? The skirting is only along the bottom and the fridge is usually lifted from the ground. I don't think the fridges vent out to the side either (most are at the rear)? The fridge does get warmer on the sides but surely if you have enough clearance on the sides except for the skirting area that would be sufficient? The doors should still open if you're looking at french door fridges because the bottom draw (where the more confined space is) slides outwards
Re: Building with Metricon 4262Jan 11, 2017 6:18 pm Orpheus You can also get the integrated fridge from F&P which only need 3mm spacing for the door. https://www.fisherpaykel.com/au/kitchen ... 90AU1.html @Orph Build thread: viewtopic.php?t=78328 Home Furniture: viewtopic.php?t=80551 Technology Hub: viewtopic.php?t=83663 Landscape Design: viewtopic.php?t=80645 $5699 Only double the price of the comparable free standing model!! Re: Building with Metricon 4263Jan 11, 2017 6:22 pm anonymous- Would the skirting negatively impact the fridge space that much? The skirting is only along the bottom and the fridge is usually lifted from the ground. I don't think the fridges vent out to the side either (most are at the rear)? The fridge does get warmer on the sides but surely if you have enough clearance on the sides except for the skirting area that would be sufficient? The doors should still open if you're looking at fridges because the bottom draw (where the more confined space is) slides outwards Yeah thats what we're thinking now.. itll squeeze in but we really have 950mm to play with for a 908mm fridge. Under the official recommended spec at 20mm instead of 50mm each side, but have plenty of space above in the void behind cupboards. Should work. Building the Metricon Fortitude 32, blogging the development at - https://fortitude32.wordpress.com/ Build thread - https://forum.homeone.com.au/viewtopic.php?f=31&t=85627 Re: Building with Metricon 4264Jan 11, 2017 6:23 pm pauldab Orpheus You can also get the integrated fridge from F&P which only need 3mm spacing for the door. https://www.fisherpaykel.com/au/kitchen ... 90AU1.html @Orph Build thread: viewtopic.php?t=78328 Home Furniture: viewtopic.php?t=80551 Technology Hub: viewtopic.php?t=83663 Landscape Design: viewtopic.php?t=80645 $5699 Only double the price of the comparable free standing model!! Hehehe, but it will look awesome! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Or this Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ @Orph Build thread: viewtopic.php?t=78328 Home Furniture: viewtopic.php?t=80551 Technology Hub: viewtopic.php?t=83663 Landscape Design: viewtopic.php?t=80645 Orpheus Building the Metricon Glendale 38|Sydney Re: Building with Metricon 4265Jan 11, 2017 6:24 pm techau anonymous- Would the skirting negatively impact the fridge space that much? The skirting is only along the bottom and the fridge is usually lifted from the ground. I don't think the fridges vent out to the side either (most are at the rear)? The fridge does get warmer on the sides but surely if you have enough clearance on the sides except for the skirting area that would be sufficient? The doors should still open if you're looking at fridges because the bottom draw (where the more confined space is) slides outwards Yeah thats what we're thinking now.. itll squeeze in but we really have 950mm to play with for a 908mm fridge. Under the official recommended spec at 20mm instead of 50mm each side, but have plenty of space above in the void behind cupboards. Should work. 20mm is flush with the door or with the fridge chassis? @Orph Build thread: viewtopic.php?t=78328 Home Furniture: viewtopic.php?t=80551 Technology Hub: viewtopic.php?t=83663 Landscape Design: viewtopic.php?t=80645 Orpheus Building the Metricon Glendale 38|Sydney Re: Building with Metricon 4266Jan 11, 2017 6:49 pm Orpheus techau anonymous- Would the skirting negatively impact the fridge space that much? The skirting is only along the bottom and the fridge is usually lifted from the ground. I don't think the fridges vent out to the side either (most are at the rear)? The fridge does get warmer on the sides but surely if you have enough clearance on the sides except for the skirting area that would be sufficient? The doors should still open if you're looking at fridges because the bottom draw (where the more confined space is) slides outwards Yeah thats what we're thinking now.. itll squeeze in but we really have 950mm to play with for a 908mm fridge. Under the official recommended spec at 20mm instead of 50mm each side, but have plenty of space above in the void behind cupboards. Should work. 20mm is flush with the door or with the fridge chassis? @Orph Build thread: viewtopic.php?t=78328 Home Furniture: viewtopic.php?t=80551 Technology Hub: viewtopic.php?t=83663 Landscape Design: viewtopic.php?t=80645 Flush one looks mint. Building the Metricon Fortitude 32, blogging the development at - https://fortitude32.wordpress.com/ Build thread - https://forum.homeone.com.au/viewtopic.php?f=31&t=85627 Re: Building with Metricon 4267Jan 11, 2017 7:10 pm Mel sydney RegVic That looks like a very dumb thing to do... a switch to close and open zones and a modern controller right on top... Yes. I don't care about on and off switch below. When they told today that zone controllers get busted i got f%$$ mad.... Is it still possible to upgrade to the controller that includes the different zone controls? Metricon Liberty 45, Ryde NSW viewtopic.php?t=82846 Build thread: Metricon Liberty 45 in Ryde, NSW Re: Building with Metricon 4268Jan 11, 2017 7:17 pm Quirmeball1280 Mel sydney RegVic That looks like a very dumb thing to do... a switch to close and open zones and a modern controller right on top... Yes. I don't care about on and off switch below. When they told today that zone controllers get busted i got f%$$ mad.... Is it still possible to upgrade to the controller that includes the different zone controls? Metricon Liberty 45, Ryde NSW viewtopic.php?t=82846 So default is 2 zones (day/night) so 1 zone for each storey. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ @Orph Build thread: viewtopic.php?t=78328 Home Furniture: viewtopic.php?t=80551 Technology Hub: viewtopic.php?t=83663 Landscape Design: viewtopic.php?t=80645 Orpheus Building the Metricon Glendale 38|Sydney Re: Building with Metricon 4269Jan 11, 2017 7:43 pm Orpheus Quirmeball1280 Mel sydney [quote="RegVic"]That looks like a very dumb thing to do... a switch to close and open zones and a modern controller right on top... Yes. I don't care about on and off switch below. When they told today that zone controllers get busted i got f%$$ mad.... Is it still possible to upgrade to the controller that includes the different zone controls? Metricon Liberty 45, Ryde NSW viewtopic.php?t=82846 So default is 2 zones (day/night) so 1 zone for each storey. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ @Orph Build thread: viewtopic.php?t=78328 Home Furniture: viewtopic.php?t=80551 Technology Hub: viewtopic.php?t=83663 Landscape Design: viewtopic.php?t=80645[/quote] Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ We got same unit and no cooling at all. If FAN air works then aircon is working to vaccaro tech theory. Is there any device to prove aircon cooling temperature issue? Cheers Re: Building with Metricon 4270Jan 11, 2017 8:17 pm Mel sydney Orpheus Quirmeball1280 [quote="Mel sydney"][quote="RegVic"]That looks like a very dumb thing to do... a switch to close and open zones and a modern controller right on top... Yes. I don't care about on and off switch below. When they told today that zone controllers get busted i got f%$$ mad.... Is it still possible to upgrade to the controller that includes the different zone controls? Metricon Liberty 45, Ryde NSW viewtopic.php?t=82846 So default is 2 zones (day/night) so 1 zone for each storey. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ @Orph Build thread: viewtopic.php?t=78328 Home Furniture: viewtopic.php?t=80551 Technology Hub: viewtopic.php?t=83663 Landscape Design: viewtopic.php?t=80645[/quote] Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ We got same unit and no cooling at all. If FAN air works then aircon is working to vaccaro tech theory. Is there any device to prove aircon cooling temperature issue? Cheers [/quote] The thermostat on yr controller says 18oC so best to use another thermometer in the same room and it should show the same temp. If not then the aircon is not working..... @Orph Build thread: viewtopic.php?t=78328 Home Furniture: viewtopic.php?t=80551 Technology Hub: viewtopic.php?t=83663 Landscape Design: viewtopic.php?t=80645 Orpheus Building the Metricon Glendale 38|Sydney Re: Building with Metricon 4271Jan 11, 2017 8:20 pm Orpheus Mel sydney Orpheus [quote="Quirmeball1280"][quote="Mel sydney"][quote="RegVic"]That looks like a very dumb thing to do... a switch to close and open zones and a modern controller right on top... Yes. I don't care about on and off switch below. When they told today that zone controllers get busted i got f%$$ mad.... Is it still possible to upgrade to the controller that includes the different zone controls? Metricon Liberty 45, Ryde NSW viewtopic.php?t=82846 So default is 2 zones (day/night) so 1 zone for each storey. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ @Orph Build thread: viewtopic.php?t=78328 Home Furniture: viewtopic.php?t=80551 Technology Hub: viewtopic.php?t=83663 Landscape Design: viewtopic.php?t=80645[/quote] Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ We got same unit and no cooling at all. If FAN air works then aircon is working to vaccaro tech theory. Is there any device to prove aircon cooling temperature issue? Cheers [/quote] The thermostat on yr controller says 18oC so best to use another thermometer in the same room and it should show the same temp. If not then the aircon is not working..... @Orph Build thread: viewtopic.php?t=78328 Home Furniture: viewtopic.php?t=80551 Technology Hub: viewtopic.php?t=83663 Landscape Design: viewtopic.php?t=80645[/quote] Where is that in main crontroller? I can see outside temp and air cooller temp to set. Did you see my controller pic? Re: Building with Metricon 4272Jan 11, 2017 8:47 pm Mel sydney Orpheus Mel sydney [quote="Orpheus"][quote="Quirmeball1280"][quote="Mel sydney"][quote="RegVic"]That looks like a very dumb thing to do... a switch to close and open zones and a modern controller right on top... Yes. I don't care about on and off switch below. When they told today that zone controllers get busted i got f%$$ mad.... Is it still possible to upgrade to the controller that includes the different zone controls? Metricon Liberty 45, Ryde NSW viewtopic.php?t=82846 So default is 2 zones (day/night) so 1 zone for each storey. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ @Orph Build thread: viewtopic.php?t=78328 Home Furniture: viewtopic.php?t=80551 Technology Hub: viewtopic.php?t=83663 Landscape Design: viewtopic.php?t=80645[/quote] Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ We got same unit and no cooling at all. If FAN air works then aircon is working to vaccaro tech theory. Is there any device to prove aircon cooling temperature issue? Cheers [/quote] The thermostat on yr controller says 18oC so best to use another thermometer in the same room and it should show the same temp. If not then the aircon is not working..... @Orph Build thread: viewtopic.php?t=78328 Home Furniture: viewtopic.php?t=80551 Technology Hub: viewtopic.php?t=83663 Landscape Design: viewtopic.php?t=80645[/quote] Where is that in main crontroller? I can see outside temp and air cooller temp to set. Did you see my controller pic? [/quote] Yup the " temp to set" is 18oC which should be the temp as recorded by the controller where the thermostat is located. @Orph Build thread: viewtopic.php?t=78328 Home Furniture: viewtopic.php?t=80551 Technology Hub: viewtopic.php?t=83663 Landscape Design: viewtopic.php?t=80645 Orpheus Building the Metricon Glendale 38|Sydney Re: Building with Metricon 4273Jan 11, 2017 10:06 pm Thankz Orpheus. So you got controller same as mine or all zones in single controller with no zone switches separately. Cheers Re: Building with Metricon 4274Jan 12, 2017 5:48 am Mel sydney Thankz Orpheus. So you got controller same as mine or all zones in single controller with no zone switches separately. Cheers My unit has 6 zones so we had to upgrade the controller to the next model up. @Orph Build thread: viewtopic.php?t=78328 Home Furniture: viewtopic.php?t=80551 Technology Hub: viewtopic.php?t=83663 Landscape Design: viewtopic.php?t=80645 Orpheus Building the Metricon Glendale 38|Sydney Re: Building with Metricon 4275Jan 12, 2017 7:07 am Orpheus Mel sydney Thankz Orpheus. So you got controller same as mine or all zones in single controller with no zone switches separately. Cheers My unit has 6 zones so we had to upgrade the controller to the next model up. @Orph Build thread: viewtopic.php?t=78328 Home Furniture: viewtopic.php?t=80551 Technology Hub: viewtopic.php?t=83663 Landscape Design: viewtopic.php?t=80645 Hi Orph, do you have a thermostat for each zone? How does the aircon know it has reached the set temp for that particular zone? Thx Metricon Liberty 45, Ryde NSW viewtopic.php?t=82846 Build thread: Metricon Liberty 45 in Ryde, NSW Re: Building with Metricon 4276Jan 12, 2017 7:27 am Quirmeball1280 Orpheus Mel sydney Thankz Orpheus. So you got controller same as mine or all zones in single controller with no zone switches separately. Cheers My unit has 6 zones so we had to upgrade the controller to the next model up. @Orph Build thread: viewtopic.php?t=78328 Home Furniture: viewtopic.php?t=80551 Technology Hub: viewtopic.php?t=83663 Landscape Design: viewtopic.php?t=80645 Hi Orph, do you have a thermostat for each zone? How does the aircon know it has reached the set temp for that particular zone? Thx Metricon Liberty 45, Ryde NSW viewtopic.php?t=82846 I suspect we only have 2 thermostats (as we have 2 comtrollers) and the measurement comes centrally from those controllers. I don't think we have a thermostat in each zone (which often spans multiple rooms) @Orph Build thread: viewtopic.php?t=78328 Home Furniture: viewtopic.php?t=80551 Technology Hub: viewtopic.php?t=83663 Landscape Design: viewtopic.php?t=80645 Orpheus Building the Metricon Glendale 38|Sydney Re: Building with Metricon 4277Jan 12, 2017 8:46 am Orpheus Quirmeball1280 Orpheus [quote="Mel sydney"]Thankz Orpheus. So you got controller same as mine or all zones in single controller with no zone switches separately. Cheers My unit has 6 zones so we had to upgrade the controller to the next model up. @Orph Build thread: viewtopic.php?t=78328 Home Furniture: viewtopic.php?t=80551 Technology Hub: viewtopic.php?t=83663 Landscape Design: viewtopic.php?t=80645 Hi Orph, do you have a thermostat for each zone? How does the aircon know it has reached the set temp for that particular zone? Thx Metricon Liberty 45, Ryde NSW viewtopic.php?t=82846 I suspect we only have 2 thermostats (as we have 2 comtrollers) and the measurement comes centrally from those controllers. I don't think we have a thermostat in each zone (which often spans multiple rooms) @Orph Build thread: viewtopic.php?t=78328 Home Furniture: viewtopic.php?t=80551 Technology Hub: viewtopic.php?t=83663 Landscape Design: viewtopic.php?t=80645[/quote] Thanks Orph, so to get an accurate temp setting you will always need to have one of the zones that have a thermostat on I guess.. Metricon Liberty 45, Ryde NSW viewtopic.php?t=82846 Build thread: Metricon Liberty 45 in Ryde, NSW Re: Building with Metricon 4278Jan 12, 2017 10:13 am Quirmeball1280 Orpheus Quirmeball1280 [quote="Orpheus"][quote="Mel sydney"]Thankz Orpheus. So you got controller same as mine or all zones in single controller with no zone switches separately. Cheers My unit has 6 zones so we had to upgrade the controller to the next model up. @Orph Build thread: viewtopic.php?t=78328 Home Furniture: viewtopic.php?t=80551 Technology Hub: viewtopic.php?t=83663 Landscape Design: viewtopic.php?t=80645 Hi Orph, do you have a thermostat for each zone? How does the aircon know it has reached the set temp for that particular zone? Thx Metricon Liberty 45, Ryde NSW viewtopic.php?t=82846 I suspect we only have 2 thermostats (as we have 2 comtrollers) and the measurement comes centrally from those controllers. I don't think we have a thermostat in each zone (which often spans multiple rooms) @Orph Build thread: viewtopic.php?t=78328 Home Furniture: viewtopic.php?t=80551 Technology Hub: viewtopic.php?t=83663 Landscape Design: viewtopic.php?t=80645[/quote] Thanks Orph, so to get an accurate temp setting you will always need to have one of the zones that have a thermostat on I guess.. Metricon Liberty 45, Ryde NSW viewtopic.php?t=82846[/quote] Good point. Let me ask a mate who is an aircon installer to confirm. @Orph Build thread: viewtopic.php?t=78328 Home Furniture: viewtopic.php?t=80551 Technology Hub: viewtopic.php?t=83663 Landscape Design: viewtopic.php?t=80645 Orpheus Building the Metricon Glendale 38|Sydney Re: Building with Metricon 4280Jan 12, 2017 7:21 pm Do you think M can design these kind of architectural homes? I think my next house will be an architectural design home and owner builder. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ @Orph Build thread: viewtopic.php?t=78328 Home Furniture: viewtopic.php?t=80551 Technology Hub: viewtopic.php?t=83663 Landscape Design: viewtopic.php?t=80645 Orpheus Building the Metricon Glendale 38|Sydney Hi, First of all, thank you to this community for sharing your thoughts and opinions. We are in early days of our pre-contract stage for Metricon Doulton and we are… 0 10715 Hello All 🙂 We are planning to start our journey of construction our first home. We zeroed down on Metricon and henley homes based on design suitable for our lot and… 0 8157 We don’t live in VIC so want to know the exterior colours of Lumiere display so we can see it at the paint shop. Not building with Metricon so my request went… 0 17321 |
